Don Nguyen | **Vinyl Roof Wrapping Services + Stickers/Graphics and more!**
The matte black vinyl on the roof is definitely different from what most euro guys go with, but it gives it an interesting different change of pace/look. The window trim on this car was also a bit different from most cars. It was like a two tone chrome, with half of it being somewhat like a black chrome and the other half was a standard chrome finish. I decided to leave the black chrome and only wrap the regular chrome finish, to leave that two tone look.
-Don
Donathon@gmail.com
-Don
Donathon@gmail.com
If you guys want to see any specific pictures or have me take anything at a certain angle/area, let me know, and I'll do my best to get it for you next time.
-Don
donathon@gmail.com
I forgot to clean the roof before we pulled the car out, so trying to clean the roof out int he sun/heat left a lot of water streaks which showed up in all of the pictures.
I had some people ask for some closer up pictures, so I took some of around the front area, sides of the roof and around the antenna area to show you guys how clean everything is installed and there is no paint showing even around the antenna area.
Before:
After:
You can see from a little further back it's not as noticeable.
However, once you get closer, the gloss black roof starts becoming more noticeable.
-Don
donathon@gmail.com
-Don
donathon@gmail.com
-Don
donathon@gmail.com
Either way, here is a gray/graphite colored Mercedes Benz C300 that I vinyl wrapped the factory chrome window trim with my matte black finish vinyl material. We went with the matte black on this car instead of the gloss black vinyl so that the it blended in with the rubber/weather stripping around the car. The owner of this car was from around Red Lands I believe and came out to me in Orange County/Anaheim Hills to have me vinyl his car.
As a note, any other vinyl on the car was not done by me.
Before:
After:
-Don
Donathon@gmail.com
Here is a white BMW E93 M3 convertible that I vinyl wrapped the chrome window trim to give it the shadowline/blacked out look. Convertibles are a bit more tedious to do since there are so many separate pieces, but it's doable. We went with the matte black to give it a more subtle look and blend in with the rubber weather pieces that are around the window trim pieces. I believe the owner of this car was either around in Orange County or near the Los Angeles area and he came out to me in Anaheim Hills to get the vinyl work done. It was a pretty new car. Still had the red striped Euro plate on it.
Before:
After:
-Don
Donathon@gmail.com
I tried to take slightly more detailed pictures this time around, as by request, to show the edges of the roof, etc. I think that the tint/smoke shade that I used on the back tail lights give it a nice cherry red color without being too dark and completely blacking out the tail lights.
Let me know what you guys think.
Before:
During:
After:
-Don
donathon@gmail.com
Before:
After:
-Don
donathon@gmail.com
Here's a black Mercedes Benz C300 that came out to me in Anaheim Hills/Orange county to have his window trim vinyl wrapped in matte black. We blacked out the chrome on his car. Unlike BMWs, the Mercedes does not have the shadowline/black trim option.
-Don
donathon@gmail.com
Here's a SC400 that I vinyl wrapped the lower lip on the bumper in the 3M 1080 glossy carbon fiber vinyl material. The lip was fairly damaged, hence the crack which you can clearly see through the material and some other small chips along the bottom edge of the lip. I do not usually wrap lips, since they require a seam line in the middle, due to the lengths that lips usually are (~7'-8'). In the picture taken front on, you can see the small seam line a couple of inches to the left of the crack. To some that may be acceptable, while to others it may be something they'll always see/notice. Hopefully this will give you guys somewhat of a better idea of how it'll work/look.
-Don
donathon@gmail.com
-Don
donathon@gmail.com
After:
-Don
donathon@gmail.com
-Don
donathon@gmail.com
Before:
After:
-Don
donathon@gmail.com
If there is enough interest in this, I can set up a group buy type of deal for it and have a group of you guys come by in on an assigned day to all get it done.
Before:
During (only the lower rear door trim piece is covered in the gloss black vinyl in these pictures):
After:
-Don
donathon@gmail.com
Tinted/smoked left side, stock/untinted right side:
Both sides tinted:
Top portion of the headlights tinted/smoked:
-Don
donathon@gmail.com
Before:
After:
-Don
donathon@gmail.com
Before:
After:
-Don
donathon@gmail.com
Before:
After:
Blacked out the chrome trunk handle piece on the rear:
-Don
donathon@gmail.com
Flat black is on the left and matte black is on the right:
-Don
donathon@gmail.com
