Vendor Specials Special discount offers, Closeouts etc.
AutoEnginuity Diagnostic Tool For Your Mercedes!
Old Jun 30, 2015 | 06:45 PM
PelicanParts.com's Avatar
SPONSOR
AutoEnginuity Complete OBDII Diagnostic Tool Brought To MBWorld By Pelican Parts!
AutoEnginuity's Scan Tool is a professional PC, Pocket PC, and Palm diagnostics scan tool for all OBDII (OBD2) and EOBD IV+ compliant vehicles. AutoEnginuity's Scan Tool allows you to read the vehicle's diagnostic trouble codes, live vehicle sensors (including wide-band O2 sensors), actuate bi-directional controls, reset adaptations, and view inspection/maintenance system test results to quickly determine what service the vehicle requires.
The ScanTool was designed to be as easy to learn as it is powerful. It comes with an automated installation process, a complete and comprehensive User's Guide, and an easy-to-use interface. You won't have to spend valuable time learning another piece of software; you can focus on what's important - servicing the vehicle.
What AutoEnginuity's ScanTool can do:
  • Save, print, read and clear Stored and Pending P, U, B, and C Trouble Codes. Supporting P0 - P9 generic and manufacturer specific codes (including the new lettered codes (e.g., P06A0)
  • The largest manufacturer specific trouble code library of all PC/PDA-based scan tools (30,000+)
  • Read and clear Freeze Frame data
  • View live vehicle sensors in a meter, graph, or grid format
  • View oxygen sensor live data and test results
  • View all 11 Inspection/Maintenance systems and Mode 6 data
  • Unlimited logging of live vehicle sensors in TXT, XML, or CSV (1ms logging accuracy)
  • Playback your data logs for offline analysis
  • Run and query specific component and system tests. Support for generic and enhanced bi-directional tests
  • View generic and manufacturer enhanced data on the same tool
  • English or Metric (SI) units of measure supported
  • Configure your sensors' ranges, scaling value, audible alert triggers, units, and sampling rate
  • Savable configurations. Set up the interface to suit your preferences and save it so you never have to do it again
  • Supports 1996 and newer passenger vehicles, whether it be domestic, Asian, or European. SAE interfaces: J1850 (PWM and VPM), ISO-9141-2, ISO-14230 [KWP2000], and CAN [11bit and 29bit]
  • Also resets the Service indicator Lights on models from 2001 on.
