W210 Technical Service Bulletins
1999 E55
Safety Recalls
TSB Number & Issue Date TSB Title
200104001 APR 01 Recall - Replacement of Side Airbags
200104002 APR 01 Recall - Side Airbag Replacement
1999080001 DEC 99 Recall - Infant Restraint/Booster Seat Exchange
1998090002 NOV 98 Recall - Side Window Airbag Defect
98V256000 OCT 98 Recall 98V256000: Window Air Bag Inspection/Replacement
Service Bulletins
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-18_00-20 DEC 03 Engine - Oil Sludging Damage/Class Action Settlement
T-18_00-21 DEC 03 Engine - Oil Sludging/Consumption Diagnosis & Repair
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
P-82_85-198 JUL 02 COMAND(R) System - No Sound/Whistling
P-47_10-16A FEB 02 Instruments - Fuel Gauge Inaccuracy
P-47_10-23 FEB 02 Fuel System - MIL ON/DTC P03XX (Misfire)
P-82_85-170 SEP 01 COMAND(R) System - Incorrect ETA Calculation Displayed
P-82_85-171 SEP 01 COMAND(R) System - Instrument Display Not Centered
P-80_57-11 AUG 01 Ignition System - Electronic Ignition Switch Replacement
P-18_40-14 AUG 01 Engine Controls - Implausible Oil Level Messages
P-91_60-48 AUG 01 Air Bag System - Side Impact Sensor Replacement
P-47_31-12 JUL 01 Emissions, On Board Refueling Vapor Recovery Valve
S-00_00-072 MAY 01 Emission/VIN Label - Availability
S-58_091A MAY 01 Special Tool - Universal Valve Spring Tool
S-05_010A MAY 01 Tools - Universal Valve Spring Tool
S-58_20-93B APR 01 Fender/Interior/Fascia Cover - Availability
S-58_00-118 MAR 01 Engine Oil - Approved Evacuation Equipment
P-88_50-023 FEB 01 Emergency Trunk Release - Retrofit
S-00_40-071 FEB 01 Synthetic Oil Recommendations - For FFS Vehicles
S-40_10-036 FEB 01 Tires - Maintenance & Inspection
S-60_004A DEC 00 Body/Frame - Dedicated Straightening Equipment
S-58_094A DEC 00 Chassis/Frame - Dedicated Frame Straightener
S-60_00-012 DEC 00 Special Tool - M20 Resistance Welder
S-58_30-103A DEC 00 Special Tool - Resistance Spot Welder
S-58_30-115 DEC 00 Special Tool - Resistance Welder
S-60_00-008A DEC 00 Special Tool - Spot Welder
S-40_10-034 DEC 00 Tires - High Performance Tire Storage
P-91_60-44 OCT 00 Rear Door Airbag - Deactivation/Activation
P-40_10-20P SEP 00 Tires/Snow Chains - Factory Approved Specifications
DDAF82_85-U-600JUL 00 Fault in COMAND Operating and Display System
DDAF82_60-U-600JUL 00 Radio Inoperative
DDAF42_10-U-600JUL 00 Selector Lever Blocks
DDAF97_10-U-404JUL 00 Ingress of Water in Luggage Compartment
DDAF82_60-U-110JUL 00 Interference to Radio After Installing Window Screens
DDAF54_65-U-200JUL 00 PTS MIL ON For No Apparent Reason
DDAF42_45-U-810JUN 00 ESP Fault Code C1120
DDAF42_45-U-810JUN 00 Electronic Stability Program Fault Code C1142
DDAF91_00-U-301JUN 00 Electrostatic Charge on Seats
DDAF82_10-U-200JUN 00 Main Beam/Low Beam Not Operating
DDAF54_21-U-600JUN 00 Operational Problem in Upper Control Panel
DDAF15_30-U-640JUN 00 Starter Occasionally Does Not Operate
S-91_40-31A JUN 00 Seat Belt - Extensions
P-91_00-34 MAY 00 Interior - Installation of Child Restraint Tether Anchor
DDAF82_85-U-100MAR 00 Tone Settings in Sound System Not Possible
DDAH54_10-P-000MAR 00 Battery Safety Notes
DDGF42_45-U-100MAR 00 ESP Electrical and Electronics Components Location
DDAF82_60-U-600MAR 00 Radio Cannot Be Operated
DDAR54_18-P-010MAR 00 Repairing Wiring Harness Using Soldered Terminal
DDAF42_45-U-800MAR 00 Steering Angle Sensor - DTCs C1140 and C1504 Set
DDAF82_60-U-600MAR 00 Operational Problem Radio/Cassette Player
DDAF82_60-U-670MAR 00 Volume of ``Hands-Free'' System Too Low
DDAF40_10-U-200DEC 99 Increased Tire Wear
DDAF46_10-U-300DEC 99 Steering Stiff, Possible Noises
DDAF91_60-U-600NOV 99 Airbag Control Module - DTCs B1310, B1311 Set
DDAF54_20-U-670NOV 99 Electric Suction Fan Runs All The Time, Ignition OFF
S-Si-00-01-70 OCT 99 Vehicle - Roadside Assistance Program
DDAF82_10-U-200SEP 99 High/Low Beams Do Not Function
DDAF07_07-U-670SEP 99 Engine, Shakes, Misses, and Dies at Idle
DDAF42_45-U-810SEP 99 ESP Fault Code C1401 or C1405
DDAF42_45-U-620SEP 99 ESP Reacts Too Sensitively at Low Speed Tight Curves
DDAF54_30-U-240AUG 99 Digits in Display Become Darker/Not Legible
DDAF54_21-U-600AUG 99 Turn Signal Lamp Occasionally Fails to Operate
DDAF77_20-U-120AUG 99 Wind Noise at Front of Tilting/Sliding Roof
DDAF91_60-U-609AUG 99 Airbag ControlModule - DTCs 004, 007 Set
DDAF83_40-U-200AUG 99 EC Lamp ON, Cannot Be Shut OFF
DDAF72_29-U-600AUG 99 Failure of Power Window Drive
DDAF77_20-U-600AUG 99 Malfunction of Electric Tilting/Sliding Roof
DDAF83_30-U-600AUG 99 Occasional Air Conditioner Failure
DDAF88_70-U-600AUG 99 Operating Problem Exterior mirror
DDAF88_50-U-200AUG 99 Corrosion at Trunk Lid in Area of Lock Cylinder
S-58_40-107 AUG 99 Engine - Binder Heating Oven (Necessary Tool)
S-99_00-223 JUN 99 Electrical - Component Locator, Star Finder
DDGF42_45-U-100MAY 99 ESP Electrical Components Locations
DDAF42_45-U-310MAY 99 ESP is Activated Even On Slight Curves at Moderate Speed
DDAF42_31-U-600MAY 99 Engine Does Not Start, Touch Start Inoperative
DDAF54_00-U-600MAY 99 Battery Discharged/Electronic Damage - After Jump Start
DDAF82_10-U-200MAY 99 Color or Brightness Difference of Headlamps
DDAF82_10-U-404MAY 99 Headlamps/Turn Signals Mist Up or Leaking
DDAF67_30-U-600MAY 99 Side Window Opens After Closing
DDAF82_70-U-100MAY 99 Telephone Call is Interrupted When Engine Started
DDAF18_40-U-804APR 99 Engine Oil Above Max Level
P-91_18-39 APR 99 Interior - New Style Seat Covers Introduced
DDAF83_25-U-600FEB 99 Heater Blower is Noisy
DDAF82_10-U-600FEB 99 Bulb Life Short in Headlamps/Marker Lamps
DDAF54_30-U-840FEB 99 Instrument Cluster Indicates Lubrication System Faults
S-58_00-043D FEB 99 Special Tools - Inventory List
DDAF18_40-U-804JAN 99 Instrument Cluster Indicates Oil Sensor Faulty
DDAF05_10-U-145JAN 99 Arrythmic Noise at Idle, Coolant Temp. Over 40 Degrees C
DDAF13_22-U-140JAN 99 Irregular Knocking and Rattling From Belt Tensioner
DDAF82_60-U-200JAN 99 Display Flashes (All Radio Functions in Order)
DDAF82_61-U-600JAN 99 Station Storage/Cassette Slot - Warning Too Loud
DDAF98_00-U-200JAN 99 Deformation of Parts During Repair Paintwork
DDAF72_29-U-600JAN 99 Malfunction of Rear Power Windows
DDAF68_20-U-600JAN 99 Mechanism of Ashtray Housing Damaged/Jamming
DDAF91_10-U-900JAN 99 Noises From Front Seats
DDAF72_10-U-100JAN 99 Noises When Operating Front Power Windows
DDAF33_15-U-300JAN 99 Vibration/Torsional Vibration at The Steering Wheel
S-82_10-115 DEC 98 Lights - Daytime Running Lamps, Canadian Regulations
P-72_10-018 NOV 98 Locks - Front Door Lock Trim, Clicking Noise
S-00_00-068 OCT 98 Computer Software - Y2K Impacts
S-58_30-106 OCT 98 Engine - Borescope & Fiberscope Functionality
P-68_20-011 OCT 98 Interior - Reuse Matching Wood Trim From Ashtray Housing
P-72_29-017 OCT 98 Windows - Power Window Lifter Assembly Components
S-82_35-113A OCT 98 Windshield - Washer Concentrate
P-62_20-001 SEP 98 Frame - Longitudinal Member Sectioning Revision
P-SI-40_30A AUG 98 Suspension - New Alignment Tools and Procedures
DDAF42_31-U-800JUL 98 Brake Assist (BAS): Fault Code C1025
DDAF42_45-U-810JUL 98 ESP Fault Code C1142
DDAF82_60-U-600JUL 98 Making and Installing Auxiliary Wiring Harness
DDAF80_57-U-640JUL 98 Repairs for Faults of Electronic Ignition Switch
DDAF82_60-U-600JUL 98 Test of Electronic Ignition Switch
S-27_032 MAY 98 A/T - Repair/Replacement Guidelines
S-SI-14_12A MAY 98 I/M Emission Testing on Dynamometer
DDAF80_20-U-610APR 98 Central Locking Unlocked When Driving, Dome Lamp ON
DDAF80_20-U-400APR 98 PSE System Does Not Function But Pump Runs
S-82_108 APR 98 Cellular Phone - Diagnosis & Return Form
S-72_055 APR 98 Interior - Door Trim Panel Component Replacement
S-91_048A MAR 98 Airbag - Replacement Label
S-82_098 MAR 98 Cellular - (Motorola) Telephone Direct Repair Program
DDAF42_45-U-800FEB 98 Steering Angle Sensor, DTCs C1140, C1504, 015, 016, 017
DDAF54_30-U-210APR 97 ABS, MIL ON No ABS System Malfunctions
00_053 OCT 93 Maintenance - Factory Approved Service Products
DD01-82042 APR 82 External Oil Leaks
2000 E55
Safety Recalls
General Recalls
2000100002 AUG 00 Campaign - Body Sealer Application
Service Bulletins
P-67_30-12 DEC 04 Body - Side Window(s) Open After One-Touch Closing
P-91_10-83 OCT 04 Interior - Seat Cushion Rocks Makes Cracking Noises
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 OCT 04 Body - Scraping Noise From Transmission Tunnel Area
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-83_40-68 OCT 03 A/C - Unnecessary Blower Motor Replacement
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-46_20-12 JUL 03 Steering - Squeaking Noise
P-82_10-257 JUN 03 Lighting - Headlamp Bulbs Inoperative
P-07_65-31 FEB 03 Engine - High Oil Consumption
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
P-82_85-182 DEC 01 COMAND(R) System - Various Malfunctions
P-80_30-13 NOV 01 Smart Key(R) - Download Time
P-40_10-33A OCT 01 Tires - Approved Winter/Summer Tires
P-82_85-158 AUG 01 COMAND(R) System - CD Changer Returns to CD Track 1
P-58_20-114 SEP 00 Front Reinforcement - New Mounting Points & Tool Set
P-40_10-033 SEP 00 Tires/Snow Chains - Factory Approved Specifications
DDAF41_40-U-113JUL 00 Whistling/Howling From Propshaft When Cold
P-47_30-06 JUN 00 Evaporative System - Check Engine Lamp (MIL) ON
P-58-20-111 APR 00 Special Tools - Storage, Mounting, and Management
P-82_64-121A MAR 00 Radio - Voice Activated Cellular Phone/CD Changer
S-82_70-124 FEB 00 Cellular - StarTAC Portable Telephone Programming
P-82_64-121 FEB 00 Radio - Cellular Telephone/CD Changer Installation
2001 E55
Safety Recalls
General Recalls
Service Bulletins
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-82_60-161 JAN 02 Audio System - Audio Voice Control Malfunctions
P-47_20-17 OCT 01 Fuel System - Hard Start After Fuel Filter Replacement
P-07_65-14 AUG 01 Engine Controls - Rough Idle After Coming to a Stop
P-47_30-15 AUG 01 Emissions - OBD Shut-Off Valve Clicking Noises
P-82_85-152 AUG 01 COMAND(R) System - Won't Respond to Voice Controls
2000100002 AUG 01 Front Longitudinal Members - Subsequent Coating
P-54_10-053 MAY 01 Battery - New `Fleece' Battery Technology
P-82_64-135 AUG 00 D2B Fiber Optic Configuration and Version Coding
S-82_70-136 AUG 00 Timeport Portable Telephone Programming
P-82_64-141 AUG 00 Voice Activated Cell Phone/CD Changer Installation
2002 E55
Service Bulletins
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
S-82_85-205 SEP 02 COMAND(R) System - Various Malfunctions
S-82_70-179A FEB 02 Cellular Phone - V60 Programming Instructions
P-99_00-265 JUL 01 Vehicle - Technical Information Update Announcement
00, 97, abs, c1120, c1140, c1504, corrosion, ddaf0707u670sep, ddaf4245u800mar, ddaf5430u210apr, door, malfunctions, mil, occasionally, operate, p401020p, starter, system, tsb, w210
