Info on a w210 e55 wheels
Old Dec 24, 2006 | 05:23 PM
elboricua's Avatar
2000 E55
Can someone direct me or tell me the correct offset and or anything i should know on buying custom wheels for my e55? i dont want to make an ebay purchase and find out later they dont fit. All i know is that is 8.5 in the front and 9.5
Old Dec 24, 2006 | 11:19 PM
1 BAD BURB's Avatar
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
Specs:
True AMG Wheel - Not a Replica
Structure: Cast Aluminum Alloy
Size:
18x8 Front Offset: 31mm Weights: 25lbs
18x9 Rear Offset: 35mm Weights: 26.5lbs
Bolt Pattern: 5x112mm
Tires 245/40ZR18 front,
275/35ZR18 rear
Finish: Painted Silver with Machined Lip, Clearcoat
Be careful with the ebay deals... im looking thru there as well and every manufacturer i talk with says the wheels will not fit b/c of our big brakes. there is one that sells wheels, but you need new lug screws to make it work. this particular wheel has a 35mm front offset (as do most of the ebay wheels) so remember, you'll prolly need new lug screws...
Aj
Old Dec 25, 2006 | 12:22 AM
elboricua's Avatar
2000 E55
thks for the very usefull info ..btw do u know if i can go wider on the back and how much wider?
Old Dec 25, 2006 | 01:33 PM
1 BAD BURB's Avatar
wider as far as wheels or tires? i think wheels, 10" is the widest. for tires, i think that 285 or 295 is the widest... im also still looking for info on this, will let you know as soon as i find out!
Aj
Old Dec 25, 2006 | 10:31 PM
1 BAD BURB's Avatar
Taken for a bud on the other forum.
The key to your question is rim width, and offset. Most 19" rims are 8.5" in width with an offset of 35MM. Though a 255/35/19 would fit perfectly on the for mentioned rim, 10-1 it will rub the friggin' suspension nut. A remedy for a 255 front setup would be a lower offset; i.e. 30MM (good luck finding it). In all, a 245/35/19 tire would the widest up front. As for the rear, my memory suggests no wider than 285 to avoid fender rub. FYI, our E55's suspensions are tuned to the 245/275 combo.
Good luck.
i personally will stay with the 245/275 combo... It looks very nice as it is,no need to run into issues. Perhaps after my rears wear out, i'll see if a 285 fits and go from there...
Aj
Old Dec 26, 2006 | 06:17 PM
elboricua's Avatar
2000 E55
So what would you recommend, switch to 19 's or just lower it 1 inch and if i go 19's i should stay with the measurements you posted for a troubleless ride? I just need new shoes to start liking my car againg.
Old Dec 27, 2006 | 09:49 AM
1 BAD BURB's Avatar
i hear ya on trying to spice up the car!
i would stay at stock hieght if you plan on lowering... i think a few of the guys have run into rubbing issues when on 19s and lowered. 19s and stock would be fine, it'll fill up the wells nicely. then again, 18's and lowered would also look nice. keep looking for 18s... im searchin all over the place! its hard.
also, sent a pm back to ya...
Aj
