W210 AMG Brake Upgrades
Old May 25, 2007 | 06:27 PM
Mr Nu's Avatar
E36 AMG W210 /// C43 AMG W202
Hi all
Quick question, I have a W210 E36 AMG (predecessor to the E55 and only 400 off built by AMG).
Overall I am very impressed with the car but wondered if any of you have upgraded your brakes?
On the E36 I know AMG took the caliper set up from the E430 at the time as it was the biggest brake system available, and I am not sure what the E55 runs spec wise but was kind of curious if anyone has and could recommend a uprated brake system for the W210?
Mr Nu
Old May 25, 2007 | 08:34 PM
E55MKB's Avatar
96 P993T, 00 E55, 09 SL63
W210 E55 use 330mm two piece rotors and AMG sliding calipers on the front axle
Old May 25, 2007 | 08:59 PM
ROCKETW19's Avatar
06 EuroElites E55
Originally Posted by Mr Nu
Hi all
Mr Nu
i have a full set of AMG brakes off my 06 E55 with only 8 thousand miles if intrested askin $2500 OBO.
Old May 26, 2007 | 03:59 PM
sbarsap's Avatar
13 Lunar Blue GL550, 06 Imola Red BMW X5 4.8is, 04 Gold Honda Ody
Will they fit an 01 E430?
How much clearance is needed? I have 18" TSW Bremmas.
Old May 26, 2007 | 06:53 PM
ROCKETW19's Avatar
06 EuroElites E55
they will fit you car but i dont know about your offsets on your rims. 18" is big enough though. depending on offsets you might need spacers, you might not.
Old Jun 10, 2007 | 04:57 AM
soundeffects's Avatar
06 E55 calpiers and rotors will bolt directly on to a 2001 E55?? Can someone confirm they have the same caliper clearance?
Old Jun 10, 2007 | 05:59 AM
Peter Kwan's Avatar
E36
I have an E36 in Hong Kong too, I upgraded the brake system with AMG calipers/rotors and pads (for W203 model), they are good for braking. You also need to change the wheels in order to fit all the things,
Rgds,
Peter
Old Jun 12, 2007 | 12:12 AM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I can confirm that the E55 (W211) calipers and rotors will NOT directly bolt on to a E55 (W210).
Old Jun 13, 2007 | 02:51 PM
ok so these calipers don't bolt on, but is it possible to modify the w211 caliper brackets with an adjustment of the holes to fit on the w211 rotors on the w210 hub??
I mean if it is just drilling out the brackets, and the rotor had a similar offset as the w210 then it should be fairly east to do.
Anyone?
Old Jun 13, 2007 | 03:03 PM
ROCKETW19's Avatar
06 EuroElites E55
Anyone?
i was told you have to make the hole bigger. they said it is simple. now i have no clue if your rim or a stock rim will have enough space for the caliper.
Old Jun 13, 2007 | 08:17 PM
Dan Wang's Avatar
Anything is possible and I can confirm that it HAS been done before. The kingpin will have to be drilled out to accomodate the bigger bolts that go through that caliper carrier. That's the easy part. Unfortunately the w211 rotor does not mate well with the hub of the w210. The diameters are completely different with the w211 hub diameter being larger. You will have to machine a piece that fits inside the w211 rotor to make it hubcentric with the w210 hub. Once that part is done, then you will have to deal with offset. Some people that I know have gone as far as making their own hats for this setup to work.
Stock wheels will not fit and you will need wheels with better brake clearance in order for this to work.
Old Jun 13, 2007 | 08:18 PM
Dan Wang's Avatar
rumor has it that the SLK55 6 piston calipers and rotors will fit the W210 with no mods. Simple bolt on, just like the C32 brakes.
Again, OEM wheels will not fit though.
Old Jun 13, 2007 | 11:17 PM
John H's Avatar
14 E550, 07 E550, 69 Mach I, 65 Hipo, 66 Fairlane GTA Conv, 66 Fairlane GT
Doesn't the SLK use an 18" diameter wheel like the e55? This would be a slick swap if I could retain the oem wheels (I like the stock "sleeper" look).
Old Oct 29, 2015 | 10:34 PM
housew's Avatar
2000 W210 E55 AMG, 1959 W180 220S
I believe the "clearance" issue isn't the diameter but more the mounting surface to inside spoke distance to fit the front face of the caliper.
for example, stock 18x8et31 rims might not fit, but 18x8et43 rims with a 12mm spacer might because the offset if the same for fender/suspension clearance, but there is less "lip" on the rim and hence more space inside the wheel for a bigger caliper.
IF the SLK55 caliper was a bolt on I'd be all over it, I hope it is. Let the research commence
Old Oct 29, 2015 | 10:35 PM
housew's Avatar
wow that's an 8+ year old thread. sorry for excavating, but at least I searched :P
Old Oct 31, 2015 | 01:26 PM
illest's Avatar
w210 AMG or S213
look at this thread. I think he used clk63 calipers
Old Nov 16, 2015 | 03:30 AM
kaype's Avatar
W109 300SEL6.3, W123 280TE, W123 200T, W210 E55
SLK55 are direct bolt on ... front and rear. but rear only if you drive a w210 sedan, the stationwagon has m12 bolts for the calipers.
SLK55 has 3 different Brake setups:
6/4 piston - 340x32mm front and 330mm rear - pre face lift (all)
6/4 piston 360x32mm front and 330mm rear - facelift with Performance Package
4/2 piston - 345x32mm front and 330mm rear - facelift without PP
Also the Setup from the CLK63 W209 is the same ... 360mmx32mm 6 piston and 330mm 4 piston ... i drive these on my car
Old Nov 16, 2015 | 03:44 AM
cm60k's Avatar
Great write-up Fabian..
ZAYED,,
Old Nov 16, 2015 | 03:47 AM
kaype's Avatar
thanks
