reset ECU and other ??
also how i clean the MAF and which product i should use..
How do i access the air filters?
anybody have the AC diagnostic page?
thanks
99 E55 euro
to clean maf simply use some good quality cleaner than leaves no residue..
and climate info i haven;t seen 1, see if someone else can help chap.
the air filters are easy, take engine cover off front , by tugging them, air box is simply pushed on so pull that up and it all pops off, screws are located under it, so once off easy!!!!
When my light came on I went to autozone to get the codes read to me. Try that unless you already have with no luck. You could always try the ML section.
