HELP!Missing segment in Instrument pod
Old Jul 26, 2007 | 09:25 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Guy, My dash display in the lower right and left bottom is missing segments. I can't tell what the Temperture is and what ever is displaying on the lower right bottom.
Any idea where to get it fix? If i have to take it to the dearship how much will my *** hurt?
thanks!
Old Jul 26, 2007 | 10:19 AM
ProV1's Avatar
MB, BMW
very common failure. new unit at dealer = around $1200
u can get it repaired for $250 here
Old Jul 26, 2007 | 10:29 AM
Anyone know how to remove the instrument cluster pod??
thanks!
Old Jul 26, 2007 | 11:04 AM
Wagondad's Avatar
01 E55 AMG
I used those guys and very good job and much
cheaper than dealer. My local MBZ mechanic removed and reinstalled the cluster for $75.
Old Jul 26, 2007 | 01:11 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
thanks!
One will need the MB Combi Hooks X2 to remove the Combi at the 3 and 9 O clock position or Remove the under dash panel and push the combi out
Old Jul 26, 2007 | 05:09 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Please don't be afraid to give a hard tug or pull when trying to get the cluster out. As long as you've hooked the hooks correctly, there won't be any damage. If the cluster has never been removed it could be a bit "stuck" and hard to remove the first time.
Old Jul 26, 2007 | 05:38 PM
where can I get these hook to remove the cluster??
Anyone remove there yet? any tip or picture??
Old Jul 27, 2007 | 12:25 PM
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWD1V
Place the hooks where Mark mentioned in the 3 o'clock and 9 o'clock positions by entering the hooks through the little space between the wood molding and the edge of the cluster. Make sure that the hooks are facing up or down when you insert them and then twist them inward so that they grasp the back of the cluster. Pull on them lightly to make sure they have a good grasp and them apply more pressure until you feel the cluster disconnect and begin to slide out. If when applying more pressure the cluster does not disconnect, give the hooks a pretty good jerk towards you so as too unlatch the cluster and slide it out.
To re-insert the cluster, the slide it into the dash in the same manner as when you removed it and it will sit flush and the light will come on as soon as it is connected. I didn't take any pics when I did mine and I should have but it's pretty easy and straight forward. Good luck...
Old Aug 14, 2007 | 12:23 PM
If this is a common problem on all our car why isn't there a recall by the manufacture to do something about it
Also, does anyone know if the car will run without the instrument pod hooked up. I wnat to sent it out to get it fix but I need my car to go to work. I was think if it work without the pod hooked up I will sent it out and just drive my car for a few day without the pod.
Old Aug 14, 2007 | 01:44 PM
phil55's Avatar
2001 e55
Not a chance Peter. No cluster...no run.
Old Aug 14, 2007 | 03:13 PM
dang it!
has anyone try to drive it with out the pod hooked up?
Old Aug 15, 2007 | 12:26 AM
ProV1's Avatar
MB, BMW
i am getting my cluster repaired this week. will try to remember to take pics w/ my cell when i remove the cluster.
Old Aug 15, 2007 | 10:17 AM
For how much and where are you having it repaired???
Old Aug 15, 2007 | 12:34 PM
ProV1's Avatar
MB, BMW
$250. will do a full report once it's done.
Old Aug 15, 2007 | 10:43 PM
SleepersRock's Avatar
2008 W211 E63
Man am I glad I got a new one "100% under emissions warranty." Didn't cost me a penny...well actually I got my firend a gift certificate for a detail job for his C43.
$1200 would have sucked.
Anybody delt with this company: CNA National (www.cnanational.com)?
I am thinking of buying a warranty from them for any major repairs like the control arm bushings, AC compressors, etc that may go wrong in the next year.
