4-Wheel Alignment Spec
as i look at mine here's numbers
left/right camber at 0 degree Toe (as close to 0 as possible i guess, i had -1 degree or so within spec)
left/right caster 5 degrees
left/right Toe pressed as close to 0 as possible (acceptable looks like 0-0.10)
steer ahead 0 (acceptable -0.03 degrees to 0.03)
left/right rear camber -1 degree
left/right rear toe 0.16 (accetable 0.02 to 0.32)
rear thrust angle 0 (acceptable -0.15 to 0.15)
