anyone know where the radiator drain plug is located at? How does one access it? Any DIY tip? thanks
Nope sorry but I had mine done at the shop. They sucked it out of the top with this tall double tube looking machine and then the new fuild went in the same way from this machine. It was pretty quick and quite interesting the way it was done.
radiator drain plug is accessed by first removing the plastic cover from the bottom, you'll see a red plug near the driver's foglight.
engine block plug is harder to get to, but must be accessed in order to completely drain all the old fluid out.
