Anyone Know?
Old Oct 10, 2007 | 01:28 AM
Nocturnal-G's Avatar
2002 E55 AMG
Anyone Know?
Does anyone here know the consequences of a dealership selling a car with a broken Check Engine Light on purpose?
Thanks guys.
PS. If you want to know, I did some research/talked to a mechanic/and tested out my car. I basically started it, took off the fuel tank cap, and sat there... waited for the CEL to come on. It never did.
PS#2. I have a Carfax Guarantee on it.
Old Oct 10, 2007 | 11:38 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Thanks guys.
The consequences would be severe, it's called fraud, but good luck trying to prove it...
Old Oct 10, 2007 | 12:33 PM
ruBENZ's Avatar
2000 E55 AMG
Surely, there would be a consequence if the allegation is true. But, are you sure the check engine light (bulb) is malfunctioning. Try turning the ignition key to the on position (without starting the engine). The check engine light should appear to the right of the tachometer. If it does not illuminate, then the bulb is burnt out. If it does illuminate, then the source of your issue may be the ECU. Here the consequences will be costlier. More so than a burnt out light bulb. Nonetheless, removing your fuel cap will not always produce a CEL immediately. The ECU may have to go full cycle before it senses the loose fuel cap. Hope this helps.
Old Oct 10, 2007 | 04:27 PM
2002 E55 AMG
Yeah... the bulb comes on during light check. I'm sure the dealer did some scandalous work to the car before they sold it and it's computer related.
Old Oct 11, 2007 | 09:09 PM
jordanst2's Avatar
1999 e55 (past), 2002 CLK55 (past), 2004 E55 (present), 2008 Z06
I suggest that you stop wasting bandwidth, and contact the California bureau of automotive repair. The can provide you with a means to initiate a claim (assuming you have one).
Old Oct 11, 2007 | 09:29 PM
scottster77's Avatar
CLK320, Honda Ruckus, pinto & BMX
damn, that sucks.. one thing i can't stand is sketchy, fishy, shady dealerships... hope you can take them down!!!
Old Oct 11, 2007 | 10:56 PM
2002 E55 AMG
Well I called in about sueing them, and told them to get ready. They were supposed to call me today, and still haven't called. Blah.
