rear window sunshade won't work
Old Oct 25, 2007 | 01:40 AM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
hi guys,
my rear window shade won't go up. how common is this, and what is the likely cause and solution? i pushed the button up/dn - nothing.
did something come off track? is it a fuse? hmm....
thx.
Patrick
Old Oct 25, 2007 | 11:40 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Do you here anything when you push the button??? If you here nothing then either there is not power or the motor is bad. Try giggling it back and forth to see maybe if it's stuck and then check the fust panel. Is there anything else not working on the car because I'm not sure if the fust only runs the sunshade or if it has other electrical things on it...
Old Oct 29, 2007 | 01:34 PM
felthove's Avatar
2002 E55
I have a new switch I can sell you that may fix your problem. It's an easy install (about 3 minutes, no tools required). PM if interested.
