Traction and stability control systems
Old Dec 13, 2007 | 07:02 AM
Pross's Avatar
Ford
Hi all,
I need to know if the traction and stability control systems on a W210 E55 can be switched off. And when off, are lairy, smokey antics an option?
Many thanks.
Old Dec 13, 2007 | 06:07 PM
SleepersRock's Avatar
2008 W211 E63
The Traction Control can be switched off (warning light appears in dash /!\), but MB technology still seems to butt in to "protect" the car. That said I can garuntee you that smokey antics still can and will happen! Donuts, burnout, drifting are all possible!
Old Dec 14, 2007 | 11:24 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
I don't remember what it's called but you have to put the car in dyno mode or something like that to get it to completely shut off. There are instructions on how to do this in here if you search.
Old Dec 14, 2007 | 12:35 PM
RAFFIE55's Avatar
Used to drive E55
I think you have to unplug something under the hood (drivers side). That will completely turn of traction control. However it also will disable the ABS, since they are controlled together. I am not 100%. Double check with another W210 guru.
Old Dec 14, 2007 | 12:39 PM
RAFFIE55's Avatar
Used to drive E55
Oh yeah here it is
https://mbworld.org/forums/showthrea...=dynomode+w210
Old Dec 14, 2007 | 01:21 PM
Thanks Raff! I knew it had to be called "Dyno Mode!"
