Fuel sending unit
Cheers, Max
I was told that by a MB Service Manager....as I mentioned before, I use the Chevron Techron gasoline additive (Fuel System Cleaner) in my tank every so often....and my sending unit works perfectly well. Don't know if that is why it does however?
Also you mentioned your car "sat all winter"....that can create water in your fuel and other issues....perhaps you should drain your tank and start over with a new unit? Wasn't the last one under some kind of a 90 day warranty at least?
