Brake Rotors....
Brake Rotors....
What would you recommend for replacement front brake rotors and pads?
And for Pads?
http://www.autoanything.com/brakes/61A3071A0A0.aspx
And for Pads?
2000 E55 AMG
And for Pads?
And for Pads?
MB
OEM rotors specifically for the w210 E55 is a GOOD thing since I believe the original ones are 2-piece floating rotors! This is why the cost factor for EACH rotor is approx double the price of a Zimmerman rotor.
(left rotor is part no. 210-421-1812-OE and right rotor is part no. 210-421-1912-OE)
OEM rotors, pads, and sensors (you'll need three sensors; two front, one rear. All for just under $800. shipped. http://germanimportedparts.com/ A reputable independent brake shop will install for ~$300. In all, at least $700. less than the stealership. Good luck.
2000 E55 AMG
The price point included all four rotors. The front rotors are $280 each or $460 for a set. Go to this site and checkout the price point for the additional rotors, pads, and sensors:
2104211812, amg, bad, brake, e50, germanimportedpartscom, mercedes, piece, rotor, rotors, w210, zimmermann
