AC Compresser does not come on
Used to drive E55
Hey Guys,
My AC went out today. I noticed the two fans up front are not coming on. They usually come on went I turn the AC on. So my question is do I have more than one problem? Does something control the compressor. Some fuse or relay. or is the compressor not coming on because it's dead. Also why are my fans not on? Is it related to the compressor?
Anybody experience this....
I have. The same thing happened to me where there was no airflow from the main vents, but the side ones worked ok.
It was a small problem where a little gray plastic tube just behind the MAF had become detached from its entry point into the firewall. My service tech cut another longer piece of plastic tubing and ran that from its start point to the pipe in the firewall and the cold air came back right away. Cost me nothing. Might want to check that out first as the stock piece is way too short.
Used to drive E55
Not sure about the compressor. All I know was that no air of any kind was blowing through the center vents, and a tiny amount of air was coming thru the side vents. Connecting plastic tube solved my air problem. Good luck.
