Home from KLEEMANN after mounting headers,*pics*
1 Post
2001: Supercharged E55 AMG
I'm home fron Denmark after adding a pait of Kleemann headers. And I'm really impressed how much of a difference they made!!
415,5 Hp/5603 Rpm and 580,4 Nm/3608 Rpm at the crank in my quite light E55 with a curb weight at only 1620 KG transformed my car from a fast car to a really fast one
I actually didn't expect this big change after mounting a pair of Kleemann headers after running with ECU and a full flow exhaust for 6 months now. But I'm REALLY impressed how much faster the car is now. 4000 Rpm and up to 6000 Rpm = WOW. Or 180-265 Km/h in 4:th gear = WOW again Compared with the stock manifolds.
The people at Kleemann was really impressed with the numbers. And if I would guess,adding a Kleemann Sport Camshaft would place me around 440-450 HP with a new ECU. And if things go like I plan I will add a Kleemann S/C next spring, and I guess I'll be blowing their stated 540 HP since I guess the Supercharger ads more then 90 HP, I would guess I'm more into the 560-580 HP range I think I have a really great example of a W210 E55
I should say that I'm running Shell 99 Octane fule that we have over here in our gasoline stations
very cool mod. How much did they set you back? Also, just to confirm but the dyno is crank HP yes?
1 Post
Yes, it's crank HP I'm going to do a WHP test later on just to check the difference.
haha, fair enough. Is there anyway we can order from your source? also, what are you doing about catalytic converters?
