E55 ride height
The following data are based from the MBUSA and/or MB-AMG web site:
Data for E55: US model- Height 1445mm Weight 1715kg Tire Fr: 245/40-18 Rr:275/35-18 ROW (rest of world) model- Height 1411mm Weight 1710kg Tire Fr:235/40-18 Rr:265/35-18 Based on the above, it can probably be safely assumed that the weight difference is mostly due to the tire size diff. Tire size differences would probably account for 2-3mm (2.5mm for calc. purpose) height difference. Since Gregg T. already did his homework and found out that US and ROW E55s only differ in the springs part number (shocks and sway bars are the same), then it can be safely assumed that installing the ROW E55 spring set would lower the US E55 31-32mm (1445mm-1441mm-2.5mm) So that is the number that I will be shooting for when I installed the Euro E55 spring set on my US E55. |
E55MKB
Where did you get the sping set and how much?? Also pls post before and after spring set pics. Thanks! |
E55 euro springs set
JamE55:
I will be ordering the parts thru somebody in Europe. I am trying to order them with a Victor design steering wheel (if he can get one) otherwise, I'll get the Brabus one. |
Cool! Pls post pics and also pics of the Victor design steerin wheel. Never seen one of those before.
Thanks! |
Jam:
The Victor design wheel actually looks similar to the Brabus. Difference being on the wood/leather version, the Brabus has the wood covering the whole top and bottom version while Victor only cover the inside protion of the top and bottom circumference which I prefer (less slippery). I would not be surprised if Victor design actually make the Brabus steering. |
Victor Design pic
1 Attachment(s)
Here is a pic of the wheel for the non-multifunction steering wheel
E55MKB
That looks really nice! But what happens to the buttons on the stock steering wheels?? I mean does the Victor come with their own buttons or how does that work?? Thanks! BTW: How much are those? |
Jam:
That is the picture of the pre 2000 MB steering wheel. On the newer car, since you do not replace the airbag, you still have the control buttons on the steering wheel. |
Ah! Ok got it!
Thanks! |
After a ridiculously long wait, I just got one of the Victor jobbers in Anthracite (darker than the Charcoal color on 2000+ models) and it is Schweet. Good luck in getting one- it is a real PITA. Anyone know where I can get a set of the smoked rear taillights?
Ambisonx
Where did you get yours and how much? |
