Sluggisg E55 accelaration
Old Dec 4, 2008 | 06:42 PM
dunny's Avatar
2000 W210 E55
Hi there,
I have a 2000 E55 having done 105,000 KMs and is in excellent nick other than one recurring problem. On normal take off, it powers like running on three cylinders until it hits 75KPH and she becomes the car I fell in love with. I have taken it to MB who have done all the diagnostic testing and replaced the air mass sensor ($700) - the car ran OK for a few months then reverted back to the original problem. Brabus have also checked it out and replaced the accelarator sensor ($600) but again, after a few months, groundhog day.
We are all scratching our heads now. The only bandaid solution that has worked is to revert the factory settings which works for a few months only however I am looking for a permanent solution with too much more expensive guesswork. Help!
Old Dec 4, 2008 | 11:41 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Do pedal ECU reset, see if that helps.
Old Dec 8, 2008 | 12:42 AM
dunny's Avatar
2000 W210 E55
Thanks heaps - will suggest to my mechanic
Cheers
Old Dec 8, 2008 | 11:02 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
I think you are probably looking at a new ecu. I have had similar problems as this on several different cars. Are you still under 8 and 80,000? Probably not but thought you were close enough to ask. The ecu is covered for 8yrs and 80,000 miles in the U.S.
Old Dec 8, 2008 | 03:41 PM
dunny's Avatar
2000 W210 E55
Ouch - what's an ECU worth?
Old Dec 9, 2008 | 09:38 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
An arm and a leg but ECU rarely go out
