Wheel bearings
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Wheel bearings
Happy holidays to all .
I am wondering if someone can direct me to a post or link for a DIY wheel bearing replacement or service. Fronts are what I want to do for now , but rears wont hurt either.
Cheers
Cheers
209/W210 Estate /W211 modded by MBENZNL
Fronts are easy..
remove the calipers
remove the dust/grease caps
loosen the adjuster on the spindle ..remove it along with the outer wheel bearing
remove the complete hub/rotor
remove the inner seal
remove the inner wheel bearing
purchase a wheel bearing packer and use high temp wheel bearing grease
replace the seals
reassemble and adjust the freeplay
Rears are a PITA
They require a special workshop tool to remove and are a sealed bearing
remove the calipers
replace the seals
Rears are a PITA
Fronts are easy..
remove the calipers
replace the seals
Rears are a PITA
remove the calipers
replace the seals
Rears are a PITA
I guess it is best to get the grease from MB right?
Thank you again for your help and courtesy.
HAPPY HOLIDAYS!
2000 E55, 2007 2500 Duramax Crew 4x4, 2006 CTS
Max just got back into the office. Glad you have gotten them taken care of. Let me know if I can be of any other assitance in the bearing department.
Andy
Andy
