Lowered the E55
Old Mar 15, 2009 | 02:02 PM
CTE55AMG's Avatar
1991 300CE
Lowered the E55
So, after countless reads, and re-reads of other threads on lowering springs (H&R), and the fact that Eibach and Vogtland do not make springs for our cars...I decided to cut mine to lower the car to where I wanted it. 1 inch was my goal, and I achieved it within 1/8 of an inch variance.
I removed the original springs, used a dremel cutting wheel and took off 6 inches of coil on the front, and 5 inches of coil on the rears. I wanted to make sure there was a slight rake when I was done.
So, see the pix! I am very happy with the outcome. Only 4 hours to do the job in my home garage and saved $250 on aftermarket springs.
Ride is great, no real difference than before.
Attached Thumbnails Lowered the E55-img_5449.jpg   Lowered the E55-img_5452.jpg   Lowered the E55-img_5450.jpg   Lowered the E55-img_5451.jpg
Old Mar 15, 2009 | 02:14 PM
desired_speeds's Avatar
2007 SL55 AMG
what spring pads are you running?
Old Mar 15, 2009 | 02:32 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Sweeeet!!! nice job!!
Old Mar 15, 2009 | 03:25 PM
CTE55AMG's Avatar
1991 300CE
I re-used the stock #3's all around. They were in great shape, and I wanted to retain the thickness since I was cutting the springs.
Old Mar 15, 2009 | 03:26 PM
CTE55AMG's Avatar
1991 300CE
Thanks. Here is a picture of the coils I cut off each spring. 6 inches up front, 5 inches in back:
Old Mar 16, 2009 | 10:54 AM
nicobaires's Avatar
13' E550, 14' Ram, 99' E39 wagon
Awesome!!
Could you do mine!!
Old Mar 18, 2009 | 10:17 PM
enzo ferrari's Avatar
2001 amg e55
bitd we used to use a 7 1/4 circular saw with a rebar/metal blade.. cuts springs like butter.
Old Mar 18, 2009 | 10:21 PM
2001 amg e55
oh, your car looks great!!
Old Mar 20, 2009 | 01:24 AM
SleepersRock's Avatar
2008 W211 E63
Very nice drop bro!
Old Mar 22, 2009 | 02:26 PM
greg12m3's Avatar
2008 EVO X GSR
looks good, I like those wheels too
Old Mar 22, 2009 | 02:57 PM
MR888's Avatar
E55
Nice, how'd you do it at home? don't you need a spring compressor or some other tools to take the springs out?
Old Mar 22, 2009 | 09:12 PM
CTE55AMG's Avatar
1991 300CE
Thanks guys. I used a ZDMAK spring compressor that I bought off a board member. It was really easy on the front, the rears were a bit harder since the rear control arms have plastic covers that need to be removed, and you also need to take out the control arm pivot bolt and drop the control arm. Still, the job was straightforward. If you are thinking of doing this job, go for it!
As far as the wheels are concerned, they are Sport Editions, bought from Tirerack. These are my winter wheels (18x8) with Pirelli winter tires. They make a staggered 19 inch set (19x8 and 19x9.5) that I am thinking of getting.
Old Apr 21, 2009 | 10:50 AM
nicobaires's Avatar
Are there any major negatives with lowering the car this way besides shock life?
Old Dec 31, 2009 | 02:16 PM
RLe55's Avatar
2012 Alpina B7 xdrive
where in CT are you loacted? can we do mine? let me know.
my email is rl888@aol.com
thanks!
Ronnie
Old Jan 3, 2010 | 09:49 AM
saintz's Avatar
GL450
It reduces spring travel, meaning you can bottom out the suspension easier. It also changes the compression and rebound curve, particularly if the springs are progressive.
Old Oct 31, 2010 | 01:22 PM
raymond g-'s Avatar
99 E320
just now seeing this thread but to emphasize and clarify: coil cutting does
reduce travel, but the spring rate *increases* as a result.
Old Nov 21, 2010 | 11:27 PM
CONDEMNED's Avatar
00 E55,03 GC OVERLAND,92 CHEROKEE
The car looks great man. I think the rake makes it look more intimidating. You planning on any other exterior work now that you've lowered her?
