BEST performace exhaust set up??
Old Apr 26, 2009 | 11:42 AM
pinoyk20's Avatar
99 model w210 e55 amg
hi guys! whats the best headers, exhaust pipings and muffler set up for performance on the w210 e55 amg? and how big will be the gain??? thanks so much!!
Old Apr 26, 2009 | 03:15 PM
ob1kenobi's Avatar
moon buggy
You have to qualify your question. How much money do you want to spend?
Check out ABALONE's with Kleemann headers (for now anyway) and assess
your pocketbook.
Old Apr 26, 2009 | 11:36 PM
pinoyk20's Avatar
can you pls ost pics of abalone's exhaust?? thankso much!!
Old Apr 26, 2009 | 11:55 PM
Esh's Avatar
Esh
E55
$800 is reasonable/cheap on a decent cat-back, headers not included. As has been discussed many many times, if you want noise, just get an x-pipe.
Old Apr 27, 2009 | 03:53 AM
rikkie55amg's Avatar
1999 E55 AMG
I'm doing a custom straight through dual double pipe system with some high flow silencers. It'll be in july/August. Will give you a pricing closer to the time if you want to go custom!
Old Apr 27, 2009 | 05:19 AM
pinoyk20's Avatar
oh thats cool! can anyone pls post pics of an X pipe? thanks!
Old Apr 27, 2009 | 05:46 AM
MR888's Avatar
E55
Do a search, there are plenty of threads about it.
Old Apr 27, 2009 | 01:54 PM
Esh's Avatar
Esh
E55
+1 TONS of threads about it
Old Apr 27, 2009 | 03:56 PM
ABALONE's Avatar
2001: Supercharged E55 AMG
Hi!
I have no pics, but it's a custom made one with double 2,5", 2 race cats and 2 full flow mufflers,one smaller and then the end muffler with two 3" chrome pipes. As for headers I have the Kleemann headers+downpipe, car runs really great!
Old Apr 27, 2009 | 05:09 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
The rear half of the stock AMG exhaust system is 100% free flowing. The only way to make more power on the back half of the stock system is replacing the stock resonator with X-pipe.
Majority of the power comes from upgrading the high flow 2nd cats and upgrading stock headers.
Whether you go Long tube headers & delete primaries, or get high flow bolt-on short tube headers + high flow 2nd cats it doesn't really matter. Both setups make almost the same power but the key is getting headers and upgrading/removing one set of cats.
I recommend keeping the OEM E55 catback, it really is one of the best OEM rear mufflers I've ever seen (or heard). If you want more power & sound while still keeping it refined keep the stock rear muffler & get header, 2nd cats, & x-pipe. That is the ideal setup.
One last option for those wanting a real sleeper (max power but most refined conservative sound), is keeping the stock resonator & rear muffler in place and removing the 2nd cats replacing it with an X-pipe (which moves the X-pipe up further in the exhaust system). This will also remove the restriction from the 2nd cats completely and improve scavenging effects at high rpms even more. With this setup you would have to run high flow short bolt-on headers.
hope that helps.
Old Apr 27, 2009 | 05:18 PM
ob1kenobi's Avatar
moon buggy
Search function will help you out a lot
Old Apr 27, 2009 | 06:36 PM
LeeRod80's Avatar
99 E55 AMG
Hope this helps....
https://mbworld.org/forums/w210-amg/...installed.html
Old Apr 30, 2009 | 08:47 PM
saintz's Avatar
GL450
+1 to everything AMS said.
I think I posted this in the identical thread on another forum. Stock muffler and piping is fine. Remove or swap to high flow cats, add better header, and add an X into the system for more power.
Old Apr 30, 2009 | 09:14 PM
1999 E55 AMG
hi guys and gals,
can one of you with the tech and science experience tell me if i cut off my exhaust pipes from the moment they form the combined CAT, then make the exhaust from each header free flowing with only a high-flow silencer into a straight pipe out to the back of the car (i am cutting the wheel well in the boot of the car to make room for the exhaust on the right side of the car (I drive a left hand drive E55)). Will this give me power or reduce the pressure from the exhaust so much it will impair the engine? I'm hoping to do this in the next month and would love to hear from anyone who has made the E55 into a dual exhaust setup if this helps or hinders
Old Apr 30, 2009 | 11:19 PM
AMG
You will most likely lose torque running a true dual setup since the back pressure will drop too much. The majority of the restriction is in the front portion of the exhaust system. Any time you reduce back pressure significantly after a restrictive bottle neck in the system you run the risk of losing torque because gas velocity drops off and you create turbulence. Keeping the rear portion of stock exhaust and upgrading the front half is the best route for power.
If you are going for looks I guess it doesn't really matter then. Just know that you are paying a lot of money to lose power (which is tough to accept for most people) in exchange for the quad tip look. It will also be significantly louder (maybe too loud). As long as you are ok with this then I guess nothing can stop you. Just remember going that route is irreversible, you cannot go back so make sure its what you want. In addition it will significantly effect the cars resale value since most people wanting to purchase a car don't want it to be hacked up, therefore you may not get a good price when it comes time to sell (if that is a factor for you). hope that helps.
Old May 1, 2009 | 12:15 AM
armaniE55's Avatar
2012 CLS63 AMG
Constantly dropping Knowledge Although our cars should have came with the dual exhaust in the first place-
