Nitto INVO
UPDATE:
Note: this is conducted in W210 E55 AMG with minor modifications (H&R Sport Spring, Bilstein Sport Shocks with #2 pads in front and #1 in rear, Reso delete, X-pipe). Tires are classified as Ultra High Performance with Performace Rating of WY. Current tire set up on 245/40/18 and 275/35/18 on AMG Mono Block Aero II. 18x8 and 18x9.
First thing I noticed about the Invo was the revolutionary and asymmetrical thread design. The outside shoulder was wide while the groove on the outside was thin making the surface shoulder block really large, it's comprised of sharp angles and criss cross grooves. The inner half is made up of solid block continuous piece (continuous inner rib provides stability under braking and accelaration) with large voids.
The first minute of driving around town, I did notice a difference between the Invo and my previous tire Michelin PS2's the difference is the noise. As I said before I found the Invo's are extremely quiet, compared to the previous tires I have used in the past Goodyear Eagle F1 GS-D3 EMT; Dunlop Direzza Sport Z1 Star Spec.
Driving impression – Dry conditions
I did a high speed turn and I found the traction to be substantial with the car failing to break away (Electronic Stability Program Off), did also a high speed test on the freeways late at night and open lots, (did quick lane changes and the stability of the car felt noticeably better.) and was impressed how quiet the tires are but the grips are about the same. The comfort level was about the same as my previous tires Michelin PS2. I have not tested it for wet traction since the weather here in the bay area are always sunny.
Overall, I am happy and impressed by the Invo. I feel the Invo had better performance in dry weather compared to Goodyear Eagle F1 - GS-D3 and Dunlop Sport Z1 except for Michelin PS2.
Based on Nitto Overview:
The INVO – tread technology without compromise. This ultra-high performance tire refused to compromise on performance, ride refinement, or quality. State-of-the-art computer engineering and digital audio testing equipment produced a tread pattern that reduces perceived road noise, provide excellent comfort, and delivers exceptional traction in both and dry conditions. The result – a tread pattern that is unique and fuctional.
I'm planning on going with the INVOs in the future!
I need the front/rear toe, camber & caster specs because i feel that the specs in owr alignement machine are not very correct because the car comes light unstable before alignement! in owr workshop
someone can help?Help is very appreciated
Fabio Daniel
