pulled CEL codes today....
Old Jul 18, 2009 | 01:12 PM
e55 addict's Avatar
check sig ;)
well with my "extreme" exhaust setup my car got CEL codes.....not the o2's, not the MAF.....the code was fuel trim on bank 1 and 2.....PO170 and PO173.....my friend who pulled them is a BMW/Porsche tech and he said my system may be running outside oem parameters and it may need a custom map to compensate......so do I just need to do a ECU upgrade or can it be something else? I would like to figure it out before adding anything else....
Old Jul 18, 2009 | 04:05 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
your other post was responded to in the other thread
Old Jul 18, 2009 | 06:15 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
how do you know its not the MAF? those coes are for the MAF my friend although I don't know if your new exhaust has something to do with you running lean.... kinda doubt it tho. when did you last change your MAF? Are you running K&N filters?
I just bought a MAF insert from German Star $130
Old Jul 18, 2009 | 06:53 PM
AMG
Almost certain its worn/old MAF and upstream primary O2 sensors, just b/c there are no codes doesn't mean they aren't bad.
Old Jul 18, 2009 | 06:56 PM
e55 addict's Avatar
check sig ;)
ok ok on monday I will be replacing the maf and o2's.......what brand do you recommend...Bosch?
Old Jul 18, 2009 | 07:05 PM
AMG
Yes, www.azautohaus.com has the two from OEM Bosch plug-in replacements for only $129 each. The rears are only $95 each. (do NOT buy the solder/splicing kind). AZ Autohaus has the cheapest prices around usually and the prices always include free shipping for any order over $50.
You need two front ones, both L & R (two rears are optional and are only really there to make sure the primary cats are working or exist at all).
http://www.autohausaz.com/search/pro...xygen%20Sensor
The Bosch Air Mass Sensor is only $154 from them, and comes in true New Bosch sealed packaging (DO NOT trust ebay auctions, most are fakes, used ones being sold as new).
http://www.autohausaz.com/search/pro...0Mass%20Sensor
Old Jul 18, 2009 | 07:25 PM
saintz's Avatar
GL450
Yeah, don't replace the rear O2 sensor, they don't affect fuel trims. Only front.
Old Jul 18, 2009 | 08:13 PM
armaniE55's Avatar
2012 CLS63 AMG
+1 for Autohause that's where I buy all my parts from. depending how many miles you have save yourself the cash and start with the Maf german star offers real Bosch Maf insert.... just an FYI
o2 sensors require replacement around the 100k mark
-Armani
Old Jul 18, 2009 | 09:03 PM
e55 addict's Avatar
check sig ;)
I have 64k miles.....so the maf first then the o2's.....or just do em both
Old Jul 18, 2009 | 09:51 PM
armaniE55's Avatar
2012 CLS63 AMG
Cool
eh ... depends bro. why fix it if its not broken. my take is save the extra cash for more mods
Start with the Maf first your O2 sensors should still be good
soooooooo how about some pics of your engine bay showing the headers
Old Jul 19, 2009 | 12:16 AM
AMG
In this case age can be more important than mileage. I've seen them go bad on cars with 49k miles. I would do Primary O2s first, then MAF.
Old Jul 19, 2009 | 02:10 AM
ruBENZ's Avatar
2000 E55 AMG
P0170 + P0173 = Worn MAF sensor. These codes appeared at 47K on mine. You can clean it first, but I guarantee the codes will return shortly after. Replace the MAF sensor, and your "buttometer" will thank you.
Old Jul 19, 2009 | 03:51 AM
AMG
If your car has 100k+ just replace both MAF and the two primary O2s. At that point you really need to give her a decent tune up, and doing both will do wonders to the way the car performs.
Old Jul 19, 2009 | 12:23 PM
LeeRod80's Avatar
99 E55 AMG
JUST DO IT!!! hahah
Oh, and take more videos....
Old Jul 20, 2009 | 05:49 PM
ABALONE's Avatar
2001: Supercharged E55 AMG
Why does the 2001 say i should only have part number 16274 for both left and right side?
When the 2002 says number Front left 16274 And Front Right 16353 ????????
I changed to 16274 on my car and since then the car has behaved really strange
I guess i should have a 16353 and a 16274 on my car even if it's a 2001 cause i have the Bosch ME 2.8, or???
// Magnus
Old Jul 20, 2009 | 06:07 PM
AMG
// Magnus
Hey Magnus,
Did you have the car custom tuned for your SC kit? If so then maybe it was tuned on your old O2s which could have read differently than your new ones. That could in theory be the problem. Normally each plug is individual and color coded from bosch so its very hard to install the wrong one (but I wouldn't rule that out). You may have to change the other one as well for your appropriate model year.
EDIT: After doing more research it appears that every year W210 E55 AMG used differerent O2 sensors.. The 2000 used completely different O2 sensors as well with completely different part #s. So My recommendation is buy the appropriate O2 sensor for your year model E55 (99/2000, 2001 or 2002 are unique to their model year).
Old Jul 21, 2009 | 04:24 PM
ABALONE's Avatar
Hey Magnus,
Nope, i have the Kleemann ECU Not a special tune.
Have a look at this picture on the right side (passenger)the short one on top is the one that came from Autohausaz with part number 16274 for my 2001 according to their site
BUT have a look at the longer one on the bottom, it's the stock one that says part number
0 258 006 353/354
Can't be the same as the 16274 one, it should be the same length at least?
