X pipe clarification....
Old Jul 29, 2009 | 12:13 PM
pinoyk20's Avatar
99 model w210 e55 amg
hi guys! what really does the X pipe do? i know it repalces the resonator but besides replacing the resonator what does it do? cant we just replace the resonator with a straight pipe? why use the x pipe? whats the explanation on this? thanks!
Old Jul 29, 2009 | 01:27 PM
greg12m3's Avatar
2008 EVO X GSR
Its makes more power then straight pipes and more refined tone to the exhaust note. I have had primay high flows with straight pipes w/o x-pip and with the x-pipe, x-pipe is a lot better and sounds a million times nicer. the top end "breathes" better too.
Old Jul 29, 2009 | 02:32 PM
pinoyk20's Avatar
thanks cause i have been searchin the forum for hours and coudnt find a clear answer so i guess your is a very clear one! thanks!
Old Jul 29, 2009 | 02:49 PM
saintz's Avatar
GL450
This isn't a great explanation, but it's a start:
http://www.carcraft.com/techarticles...ion/index.html
Basically, you get two benefits over a straight pipe.
First, exhaust gas has two exit paths instead of just one. Exhaust gas comes in pulses, rather than as a continuous flow, based on the firing order of the engine. A pulse coming down the passenger bank exhaust path hits the X pipe and can now proceed through both the passenger and driver exhaust path. So it effectively increases the capacity of the system versus confining exhaust gas to a single path.
Second, it increases scavenging (the effect of vacuum). An exhaust pulse is a chunk of air moving down the exhaust pipe. Like any moving object, it creates a partial vacuum behind it (think about how a large truck creates a draft behind it). This vacuum helps the engine operate more efficiently (it's pulling the bad exhaust out of the engine and pulling good fresh air into the engine). It's kind of like a very (very) small supercharger, but it works by creating negative pressure in the exhaust side rather than positive pressure in the intake side. With straight pipes, an exhaust pulse from one bank only creates a vacuum on that bank. With an x pipe, that scavenging effect is created on both banks, as it can lower the pressure of the other bank as it travels through the X pipe.
This is probably a scientifically mediocre but hopefully easy to understand explanation. If you search around Google, there is much better reading out there.
Old Jul 29, 2009 | 02:55 PM
pinoyk20's Avatar
very nice xplanation saints! so where is the best place to put the x pipe in the xhaust? is it where the resonator used to be or closer to the engine? thanks and alos whats the best design of x pipe? can anyone pls post pics? thanks!
Old Jul 29, 2009 | 08:42 PM
saintz's Avatar
GL450
Magnaflow X pipe is a good design. You want something that's smooth and gradual (narrow angle X) not abrupt (wide angle X).
Old Jul 29, 2009 | 08:46 PM
Fabio D's Avatar
210 55
what Magnaflow we need for our cars? 2,5" or 3"? what i the answer by the moders?
Fabio Daniel
Old Jul 29, 2009 | 08:51 PM
ruBENZ's Avatar
2000 E55 AMG
Fabio Daniel
2.5"
Old Jul 29, 2009 | 09:16 PM
farmer88's Avatar
99 W210 e55 amg, 97 S600, 05 honda dc5
is it posible to purchase x pipe in u.s. then have them ship it to philippines? and also highflow cats
Old Jul 29, 2009 | 10:41 PM
Silver Logic's Avatar
W210 E55 AMG
Please advice, as I was thinking of putting the x-pipe in place of the secondary cats, but if it will be of more benefit to replace the resonator, then that's where I'll put it.
pinoyk20's Avatar
thanks guys!
Old Jul 29, 2009 | 11:22 PM
Fabio D's Avatar
210 55
Thanks Rub!
Fabio Daniel
Old Jul 29, 2009 | 11:24 PM
KL2DC's Avatar
W210 E55, W211 E3504M, E90 325i
The ideal set up is to put the x-pipe as close to the downpipes as possible (with the secondary cat delete) then straight on through to the AMG muffler.
Most folks (with all cats in place) have the x-pipe where the resonator used to be.
Old Jul 29, 2009 | 11:27 PM
KL2DC's Avatar
I agree, seems to be a nice piece (although that polished stainless steel generic x-pipe everyone is using looks to be a nice piece too, cheaper as well)
They also sell Magnaflow brand 45 degree mandrel pipes to go with the Magnaflow x-pipes.
Old Jul 29, 2009 | 11:29 PM
KL2DC's Avatar
Actually I just did this mod this morning
Its everything its cracked up to be although I was expecting more decibels. I'm definitely gonna source some high-flow cats now. I was leaning more on the conservative side and declined my exhaust guy's offer to cut the secondary cats out.
Old Jul 30, 2009 | 02:19 AM
W210 E55 AMG
To further clarify, you're saying that the ideal place for the x-pipe is to put it in place of my secondary cats? Delete secondary and replace with x-pipe?
Old Jul 30, 2009 | 08:00 AM
pinoyk20's Avatar
yup its the best place maybe on the center on the whole pipe.
Old Jul 30, 2009 | 08:23 AM
saintz's Avatar
GL450
Agree. Generally you want the cross to occur when velocity is highest (to increase scavenging) and early in the system (the sooner the exhaust pulse can split itself, the lower the restriction). Most people pick the resonator location because they want to remove it anyway. Doing it closer to the engine (i.e. where the cats are) would probably be slightly better. Bear in mind the difference here is so small it's probably only theoretical (i.e. couldn't be accurately measured, even on a dyno).
Old Jul 30, 2009 | 08:35 AM
saintz's Avatar
GL450
There are a ton of companies that make pre-made ones, I'm sure you can find someone that can ship (or even someone local). Also, you can have your exhaust shop make one, it's not that hard. 4 bent pipes, cut it so they line up in an X, and weld.
Old Jul 30, 2009 | 11:29 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
+1 Right on I loooooove my X pipe going with high flows as well, this will make her sound really sweet
Old Jul 30, 2009 | 11:30 PM
armaniE55's Avatar
2012 CLS63 AMG
Talking
Originally Posted by ruBENZ
2.5"
Blast from the Past.. Nice of you to Show up
Old Jul 30, 2009 | 11:32 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
saintz - Nice write up
Old Jul 31, 2009 | 07:58 AM
W210 E55 AMG
Got it. Thanks guys.
