need help on wires
I think the general consensus is that the stock ignition wiring is sufficient. I doubt you will see any real gains, especially at that price. If you haven't changed your spark plugs, however, that might be more beneficial.
aftermarket is a lot cheaper and imo better
you can do a quick search for Magnecor set for about $170 shipped to your door.
compare that with $450+ for a set of OEM.
now compare the ease of removing them when you want, priceless.
btw mb does recommend you replace them at 6 year mark...
