AMG Wheel Fitment Question.
Old Sep 4, 2009 | 01:20 PM
Dragoncoach's Avatar
2004 SL500R / 2003 BMW M5
The W210 E55 I was waiting for is almost ready for purchase and I'm getting the itch. I'm not enamoured with the monoblocks but I've always liked the 211 E55 wheels and was wondering if someone could give me a definitive answer about whether or not the 211 AMG wheels will just bolt up without requiring any type of spacer. Can someone help? btw, I did a search and gave up after 20 minutes of reading. Thanks.
Old Sep 4, 2009 | 02:18 PM
nicobaires's Avatar
13' E550, 14' Ram, 99' E39 wagon
They should be a direct fit except that the bolts you'll need are different. They are a hybrid between the two models. They sell them at the link below.
If you call them up and explain what you are doing they will give you the exact bolts you need.
http://www.radusadirect.com/
Old Sep 4, 2009 | 03:44 PM
saintz's Avatar
GL450
You can also find aftermarket dual 5 spoke wheels that look identical and will fit, in case you have trouble finding genuine W211 E55 rims.
Old Sep 5, 2009 | 09:35 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
the W210 E55 has:
18x8.0 et31 front
18x9.0 et35 rear
What are the specs for the W211 E55 OEM rims?
Old Sep 5, 2009 | 12:09 PM
ruBENZ's Avatar
2000 E55 AMG
Originally Posted by E55 KEV
the W210 E55 has:
18x8.0 et31 front
18x9.0 et35 rear
18x8.0 et30 front
18x9.0 et39 rear
FYI, W210 OEM lug bolts: 12mm x 1.5 x 40mm (1.5"). I believe W211 lug bolts differ: W211 OEM lug nuts: 14mm x ? x ? You may require custom lug bolts due to thread design. Also, keep in mind that OEM have ball seat heads vs. aftermarket acorn heads. Good luck
Old Sep 5, 2009 | 08:21 PM
Thanks for the information.
