Steering wheel noise
02 E55; 99 CLK430 (Sold)
I did a search on this and came up with nothing. Normally I drive around with my windows open and the radio on and things but last night I was driving with the wife with the windows up and the radio off. Holy sh*t does my steering wheel make a lot of noise. Obviously you don't notice it on the highway or probably much during regular driving, but when you're driving around trying to find somewhere to park and constantly doing loops my steering wheel squeaks like no other. Anyone else have this "issue" and if so is there a fix or solution? Just seems odd how much noise it makes.
W210 E55, W211 E3504M, E90 325i
I just read up on this somewhere here...iirc its simply something to do with a rubber boot or seal that either needs replacement or lubing.
GL450
In a parking garage, your tires will be very loud on the pavement. This can be confused very easily with steering wheel/rack noise (ask me how I know). I've almost exclusively noticed this in parking garages (combination of slippery concrete and enclosed space for echo) and for some reason Mercedes, regardless of the type of tires fitted, do this more than other cars.
Steering noise is very common on these cars as well, so if you notice it on open asphalt, that's the issue. The best bet is to try topping off your power steering fluid. If you're talking a teaspoon, you're probably ok using generic brand from Autozone, but ideally and especially if you're replacing a lot, you want to use the expensive MB brand stuff. If topping off doesn't help, flushing the system will probably help. After that, you're talking about replacing various seals or perhaps even the whole steering rack, depending on the shop you take it to.
I know it's not the tires or anything steering parts related. It's definitely just the actualy steering wheel making weird noises. So I'll see what I can do. Odds are I just live with it.
1999 Mercedes Benz E55 AMG
Whenever I'm in a parking lot backing up or moving forward with the wheels turned all the way to one side and the car goes over any road imperfections,like potholes,bumps,it makes this cracking noise,almost like a pop. I also feel a small vibration in the steering wheel,it's almost like it freezes for a fraction of a second and then it lets loose making the cracking sound. It also happens when I get off the sidewalk with the wheels turned to one side.
Could this be the rack? Anyone else has this problem?
I should also mention that I've changed the power steering reservoir,flushed the system and put MB power steering fluid. The steering is really smooth besides this problem and it doesn't make noise when I turn.
Thanks.
Thanks.
Desired_speeds,you were right! Thanks.
Put it on the ramp yesterday...disaster!
Right lower control arm,cracked at the joint...rusted....afraid to drive now until the new one arrives in a couple of days. I replaced the left one 10k ago and the right one looked good....oh well...
Left side tie rod has play,the right one not too much...ordered both.
Ordered both ball joints.
Ordered left and right outer tie rod.
Driver side transmission oil cooling line leaking...ordered that too.
Now I have to install everything when they get here and do a wheel alignment.
Rear main seal leaking...not bad at all...had that for a long time...I understand these cars develop it around 60k. Wonder if I should do that too...the labor's a lot,no?
2001 E55 AMG (sold)
I did a service B (myself) and wiped all the oil away from the bellhousing. 9k miles later, I did a service A (myself again) and when I checked the bellhousing, there was very little oil accumulation. IMO, its better to leave it alone unless the leak is significant. Mine doesn't even leave drops in my parking spot. I had less than 1q of oil loss over 9k miles.
I'd leave it, just check it periodically for signs of going from a seep to a real leak. I bought mine last summer. The service notes from the Dealership recommended changing the RMS due to leaking. It was in excess of $1k for the repair.
