oil level Problem
Old Oct 1, 2009 | 07:46 PM
H35's Avatar
H35
W220 S55
oil level Problem
My on board computer keps telling me to 'check oil' and then it says 'visit workshop'. When I check the level throught the computer it says 'add 2 qts' but when I check the dip stick it's full. I even changed the oil and the exact same thing is happening.
I always use Mobil1.
Can anyone help me?
Old Oct 1, 2009 | 10:47 PM
ruBENZ's Avatar
2000 E55 AMG
Your dipstick provides the most accurate measurement. Whether an oil level sensor exists on a W210 E55 is unknown to me. It does on other models. Nonetheless, I would begin there. Good luck.
Old Oct 2, 2009 | 03:27 PM
saintz's Avatar
GL450
Your sensor is probably bad. The dip stick doesn't go bad. I think someone recently posted about their sensor.
Old Oct 2, 2009 | 05:23 PM
H35's Avatar
H35
W220 S55
Thanks. I searched but didn't find anything regarding the sensor.
Old Oct 2, 2009 | 11:30 PM
Eurosport's Avatar
monowiper
lift it up, take off the plastic and look around usually it's bottom of the oil pan somewhere...
Old Oct 3, 2009 | 10:03 AM
saintz's Avatar
GL450
https://mbworld.org/forums/c-class-w...w-replace.html
Try parts.com, they should be able to find you the right part. Not sure how similar the C class part is, but the linked thread should help you find where it goes.
Old Oct 3, 2009 | 08:28 PM
Esh's Avatar
Esh
E55
Think with your dipstick Jimmy!
