99 E55 fluids recommendations
Old Aug 11, 2010 | 10:54 AM
zend's Avatar
e500 2003
My father recent purchased a 99 E55. The car has about 170000kms on it. To be safe he wants to replace all the fluids and filters. I also want to know what other things should one check/replace?
Please recmmended the best fluids to replace. Cost not an issue.
I know the recomended engine oil is Mobil 1 0W-40.
What tranny fluid is required. (Brand and type)
What brake fluid is required. (Brand and type)
What coolant is required. (Brand and type)
What air and oil filters are required (Brand and type)
Any help would be appreciated.
Zend
Old Aug 11, 2010 | 12:59 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Zend
Only use MB approved fluids and OE parts and you be ok.
Old Aug 11, 2010 | 02:01 PM
RAFFIE55's Avatar
Used to drive E55
Zend
I've used Royal Purple on the tranny and all is good so far
Old Aug 12, 2010 | 02:55 PM
SleepersRock's Avatar
2008 W211 E63
I still use royal purple for engine oil and works great. Bit pricey compared to mobile one though.
Old Aug 12, 2010 | 04:29 PM
Shadow5501's Avatar
Car free at the moment
Seriously? Didn't you know the 722.6 transmission in your car requires fluid meeting MB 236.14 specification. Basically, anthing not specifically made for this transmission is not compatible with it.
The 722.6 requires Mercedes OE fluid, or Shell or Fuchs aftermarket. In the 722.6 you can use Fuchs Titan 4134 or 3353 fluids. Shell uses the same numbers. The 3353 was orignally introduced for the 722.6; it is superceded by 4134 which is used in the 722.9 7-speed automatic transmission. Shell and Fuchs are the OEM suppliers to MB, so it is the same stuff.
Not sure what happens if you leave plain old Dexron IV in the transmission for an extended period of time.
Old Aug 12, 2010 | 08:01 PM
RAFFIE55's Avatar
Used to drive E55
Royal purple is as good or better than MB oil. You can even go with Dextron, just have to change more often. Life time oil is a crock of Sh..t
Old Aug 13, 2010 | 10:58 AM
Shadow5501's Avatar
I don't care what you do to your own car. Have at it.
To the original poster, Royal Purple does not meet the Mercedes specification for your transmission. I strongly suggest you do not use it. Doing so is basically a science experiment on your trans. Your transmission costs $4,000, give or take, to rebuild. Your choice.
