Help locating this fuse please..
Old Aug 29, 2010 | 03:43 PM
kanno's Avatar
00 E55 AMG
so ive got some LED bulbs for my doors underlight because i thought my stock ones were all burn out but anyway i wanted to freshen them up.
so i put all new bulbs in only to find out none of them still work.
Im most certainly sure its a fuse blown/missing. Ive looked around dash, n engine compartment fuse box but couldnt find nothing that would fit the description
PS: its the little lights in the bottom of the door when you open door they light up, where would a fuse for them be located?
thanks
Old Aug 29, 2010 | 09:06 PM
desired_speeds's Avatar
2007 SL55 AMG
did you put them in with the correct polarity?
Old Aug 30, 2010 | 01:27 AM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
i just changed my interiors and door lights to led/s and didnt blow no fuses at all or didnt disconnect before swapping them out .. Maybe if you look in the fuse box on the side by drivers door chances are the fuse in in there ..and might have a spare also if it hasnt been used allready ..
+1 for the polarity .. if it doesnt light up switch the bulb around and it should but if you got fuse issues then it doesnt make a differnce .
Old Aug 30, 2010 | 06:45 AM
saintz's Avatar
GL450
Fuses are in three places: under the hood in the fuse box, where the drivers side door meets the dash, and under the rear seat. Not sure where the correct fuse would be, but you have to check all three.
