lowering springs??
1999 E55 AMG
lowering springs??
So I've finally decided that I want to lower my car, those stupid gaps in the back are just waaayyyy to big and it looks majorly ugly. The thing is though, I'm not really sure what I need to get to lower it. Some of my friends have told me to just get some lowering springs but I'm not sure which ones..any suggestions??
You can get SSI Springs off eBay. One of the members just purchased them. As far as he can tell, they work great. I'm pretty sure stock shocks will work. I'll wait for other members to give you more input.
springs
You can get fairly cheap springs on ebay to the expensive euro amg oem springs. There are quite a few choises. Check the threads here. There are plenty of write-up. Also, don't forget the pads.
I check the shims at the dealer yesterday and they quote $7 for the front a piece and $8 for the back. For about $30 if you do it yourself you can get about 0.63 inches off. That's not bad. You know with the settling in would be closer to an inch. I think the original springs are low enough. The shims are thicker for NA cars some where between #3 and #4 so you just bring them down to #1 and keep the oem springs
2001 E55 - 2008 CLS63 -2016 F-150
can the pads wear out because my driver side seems to sit lower then the pass side or would that be direct shock or spring failure ..
figure for a 10 year old car....I would say there will be some wear on the pads as your springs are sitting on the pads. Like an office chair which was sitted on everyday. If you are going to DIY on the pads, I would change the pads and see how the car sits before getting new springs. That's the cheapest way to do it before investing on springs.
this is driver side
pass side
I would take a yard stick and measure both sides...front and back and compare. The previous owner might have mixed the shims and that's the reason your car is not sittng right. Your car seems to be sitting lower...the previous owner must have switch to lower pads.
yea it was .. its seems that my driver side is sitting almost 1/2 inch lower then passenger side .. its only been like this for week or 2 before they were good all around ..
wish it was this easy , id do it myself lol
http://video.google.com/videoplay?do...95583838776006#
spring compressor
BTW I read in the benzworld forum, get the #2 pads for the front and #1 pads for the rear. Given the weight of the engine, the front will settle about an inch over time.
EDIT: i guess after reading the wiki it seems the car is still controlable .. but i still dont hear any clink or sounds but now im really gonna get it checked out .. Anyone know how much INDI'S charge to reweld if this does turn out to be the problem ..
Front Spring Perches - Some owners have reported rust problems on the front spring perches - the top perches, which hold the tops of the springs for the front suspension. The perches are spot welded to the chassis, and factory coated in a weatherproof mastic to stop them rusting, however in some rare occurrences, water gets behind the mastic causing the perches to rust, and eventually to fail - leading to collapse of the suspension. The car remains controllable. This is a problem that Mercedes USA have acknowledged. The issue is not identifiable without first removing the mastic to check.[7][8]
You might have a rusty spring perch That been said, I will not spend money on the springs as the springs are still fine. Probably get two new pads for the front and check the welds on the underside. I had that problem with my 190D a few years back and I had to get AAA to tow it to the garage. I will not drive the car until you get a look at it because you don't want the spring to cause any major body damage to the wheel well while driving it. That was what happen to my car and I had a dent on the back of the wheel ach in the 190D and broke the plastic cover on the underside of the wheel.
wheres best place to buy stock OEM springs ? checked online all i get is the H&R lowering springs everywhere .. is there any better place online compared to getting them at the dealer ..
so is the dealer only place i can get oem AMG springs >??? been lookin all over internet cant find none except aftermarket >??wtf
you sure it's the spring and not just the spring perch that needs rewelding?
or have u checked the net? ebay? etc..
how much are the dealer quoting you?
Next best bet is H&R
http://hrsprings.com/scripts/appguide.php?Mode=Application+Guide&SubMode=Find2& Year=1996&ModelID=320&q=1996%20|%20Mercedes-Benz%20|%20E55%20AMG
I could of sworn Eibach made springs for the W210 E55 but I cannot seem to locate them.
I suggest you change out your shocks as well to some bilstein sports as they have a shorter travel to accommodate the shorter springs. If you keep your stock shocks you will eventually blow them up plus if they haven't been changed by now they are past due.
Depending on how low you want to go I would also suggest going with the largest pad offered, I am running #5 up front and #4 in the rear and my car is SLAMMED (a little more than I would like but I can live with it)
Hope this helps
Thanks , i think id prefer to throw some new springs as most i have seen used have close to 100k miles on them and rather not spend for install and have them go bad in near future . But definetly let me know if u come across . Cant find any OEM on the net , will see how much dealer wants when i take it in for inspection .. Thanks again
