Rear body isolator
2002 E55 AMG Obsidian Black with Charcoal
Rear body isolator
Anyone ever bother to replace the rear sub-frame to body rubber isolators?
If so, what were your results (ex. smoother ride, less vibration or noise, et cetera)? Just curious if anyone has experienced any changes.
I can tell you it should increase the rigidity of your chassis which in turn will improve your handling as well as reduce some vibrations for a smoother ride.
I don't think I would change those unless they had visible deterioration. Also, not sure I would go with anything other than OEM rubber to avoid unwanted NVH. I have poly subframe bushings in my E36 M3 with aluminum differential mounts and it is very noticeable.
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
If that's all the cracking you have then I wouldn't bother doing them, they look like they are only cracked on the edge. Keep an eye on them but they don't look like they are ready yet.
