What Size is it??
Old Jul 9, 2011 | 12:05 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
What Size is it??
I am trying to find out the size of the E55 front sway bar. Anybody know? The standard E430 and E320 is 28mm. Is the E55 at 30mm? I have called two dealerships and both have no info.
Old Jul 9, 2011 | 01:28 AM
ruBENZ's Avatar
2000 E55 AMG
I believe OEM is 28mm front; 18mm rear. Aftermarket is commonly 30mm front; 20mm rear
Old Jul 9, 2011 | 04:51 PM
SleepersRock's Avatar
2008 W211 E63
Is there any real benefit to the slightly larger aftermarket sway bars?
Old Jul 10, 2011 | 12:13 PM
ruBENZ's Avatar
2000 E55 AMG
Doubtful. If there is, I believe most of us would have applied them by now.
Old Jul 11, 2011 | 10:18 PM
ejsheltra's Avatar
Anybody know for certain? Are you saying the E55 front bar is the same as the E320 and E430 part? That does not make sense. Can anyone take an actual measurement? I know the the Brabus bar is a 30mm unit. Would really like to know. Thanks all.
Old Jul 11, 2011 | 11:56 PM
Fabio D's Avatar
210 55
i'm pretty sure the AMG bar is not te same as the E320 - E430 visually inspected in many cars in owr workshop and for sure the E55 is larger than the others
Fabio Daniel
Old Jul 12, 2011 | 01:07 AM
desired_speeds's Avatar
2007 SL55 AMG
The e55 bars are also solid while the E320 and E430 bars are hollow.
Old Jul 12, 2011 | 02:32 AM
ruBENZ's Avatar
2000 E55 AMG
Originally Posted by ejsheltra
... I know the the Brabus bar is a 30mm unit. ..
And, Brabus is aftermarket.
Another example of aftermarket is H&R. As per site:
H&R Front Sway Bar Mercedes-Benz E300D / E320 / E320T / E420 / E430 / E55 AMG 1996-2002
H&R Sway Bars is a direct replacement of your factory sway bars and are drastically thicker than the stock bars. ...
Models Included W210
Bar Diameter 30mm
Thus, OEM is less than 30mm. Or, shall we say: 28mm front; 18mm rear.
Old Jul 12, 2011 | 03:13 AM
ruBENZ's Avatar
2000 E55 AMG
Old Jul 12, 2011 | 12:02 PM
ejsheltra's Avatar
Thanks guys for the assistance.
