Contour seat problem
Old Jan 23, 2012 | 07:33 AM
Emgee's Avatar
2001 AMG E55
Mine are not working. Have checked every fuse. Any suggestions?
Old Jan 23, 2012 | 10:13 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I believe there is a 4 prong relay by the battery, have you checked that?
Old Jan 23, 2012 | 03:01 PM
Emgee's Avatar
2001 AMG E55
Thanks, I will check it out.
Old Jan 23, 2012 | 05:53 PM
Schweinhund's Avatar
W210 E55
WHAT is not working?
Old Jan 23, 2012 | 11:32 PM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
It is the electric door mounted switch that is not working, or the pneumatic adjuster switch down next to the seat?
Old Jan 24, 2012 | 10:54 AM
saintz's Avatar
GL450
Does it make noise but not inflate? If so, you might have a leak. Two screws under the seat back will drop the back off, and you can check the hoses. Reattach with zip ties.
If it's not making inflating noises, you have a different issue.
Old Jan 24, 2012 | 11:57 AM
You seem to have 2 different problems as the electronic switch is exactly that, electronic, where as the seats inflate with air. In my C43 the air pump is located in the trunk on the passenger side wall behind the wall cover. If the pump is running intermittently (it turns on and off several times within 15-20 minutes) it usually means you have a leak. Like suggested before I would start with taking the back panel off and checking those lines. Those only fill the bolster in the C43, I am unsure of the set up for the E55 but I would bet they are similar. There should be another line running to the bottom of the seats, check those out as well. I would check the 4 prong relay like I spoke about earlier as we had a member with a C43 with very similar symptoms and that's what it turned out to be.
I hope this helps
