Heads up Display mod
After testing for a while there is a 3% variance. Meaning if your going 65 and you speed up or slow down it will be off by 3 MPH. If your cruising then your right on with what is reading on your normal cluster 100% dead on. If you woot it... it will be off by 4% again this is typical as the satellite is still trying to lock on. I'm ranting.. pics attached. Pretty bright at night and it's a clean install no wires. Hard wired into the fuse box.
I'd figured I'd share with you guys. I don't even look down anymore at my cluster to see my speed.
Armani
