Locks pop up, seats deflate
My car has always had issues with the air seats not working quite right. For a long time, I got them to work well as long as I didn't try to inflate the leg cushions.
Lately, I noticed problems again. They would be fine, then my back support would suddenly deflate. I also started noticing that my driver door lock would pop up on its own (after being auto-locked when I started driving).
If I tried to press down the driver door, the passenger door would pop up! I could unlock then relock using the dash switch, but the driver door would usually pop back up 5 minutes later. Now, I'm noticing the driver and passenger doors are popping up.
I plan to try and have a look under the rear seat and take the covers off my front seats tomorrow. I'm just not sure what to look for with the lock issues or if they are all related to leaks in the seat bladder system.
Anyone know how the locks are related?
Luckily, thus far I haven't come back to my locked/parked vehicle and found a door unlocked.
To dignose, you can plug the air supply port in each seat and see if the pump builds pressure and stops. The selector/header assembly will split and expose the supply port and bladder ports.
