Driveshaft
Old May 7, 2012 | 01:02 PM
Drewloera's Avatar
2000 w210 E55
Driveshaft
Recently, Had my car on the lift and noticed my driveshaft has a little play. I think its the cause to my clanking sound I hear on take off. Is this normal. My driveshaft support and bearings are fairly new. The black rubber bushing with the bolts connecting driveshaft is also not worn.
Old May 7, 2012 | 06:49 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Is the clanking coming from the center of the car (under the arm rest)?
I had a similar knocking sound at takeoff and it turned out to be the center support bearing. The "black rubber bushing" is called a flex disc and I do not believe it would cause a "clanking sound", if there are cracks in the flex discs you need to replace them.
I know you said your center support bearing was fairly new but from your description of the sound I would suggest starting there.
Old May 7, 2012 | 08:54 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Have you checked the u-joints? They'd allow some play and could clank if they're bad.
Old May 8, 2012 | 04:25 PM
armaniE55's Avatar
2012 CLS63 AMG
It shouldn't have any play. Either that or the part is defective (check for warranty on the part) OEM?
Armani
