lots of work over weekend
I just changed rear subframe bushings,bushings in 1 knuckle along with a new a frame,
Front brake pads, new fluid flush in rad, and brake,valve cover gasket, replaced front spring pads and added the camber bolts to the a frames , sucks cuz I need a new brake pad sensor For the left side ,frekn broke when I went to swap it out!!!!
