2000 E55 BAS/ESP and ABS lights come on
Old Jun 12, 2012 | 12:56 AM
srydy's Avatar
2000 E55
My 2000 E55’s ABS & ESP lights come on when I step on the brakes, they don't always come up first thing when I start up and press the brake pedal to shift but after driving a few miles and braking a few times . I had all the pads/rotors replaced about 2 years ago. I would like to save a few bucks this time around and request some advice from the forum. I use my car for regular commute (8 miles each way) I don’t race/abuse, drive or brake hard, I practically drive it like it were a mini-van.
1) Is it normal that the brakes wear out every 15K - 20K miles? Do you think it is just the brake light gone bad?
2) Is the brake replacement so complicated that a regular auto-shop can’t do it? Does it have to be done by a certified Mercedes shop?
3) How do I know if all 4 rotors+pads need to be changed or if it is just the front/rear?
4) What quality alternatives to OEM brake parts are there and where can I buy them?
Thanks for your help,
Srydy
Old Jun 12, 2012 | 01:19 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Srydy
I do not think you need to replace your brakes as your brake light would show up and not the ESP/ABS light. It sounds like your brake pedal switch might have gone south. Cheap and easy to replace.
To answer your questions:
1.) your brakes should last longer than 15k-20k
2.) brakes are SIMPLE on the E55 (same as my C43) you could DIY or have any indy shop do it
3.) Feel the rotor, if you can feel a deep groove it is probably time for new rotors which are not cheap ($250+ a piece for the front rotors).
4.) if you search on the C43 forum there is a thread about cheap rotors. They come off of a C230k and are 4mm smaller in diameter if I remember correctly. There are several members that have gone this route. They are not 2 piece like the AMG rotors but they are 1/2 the price so if you are not all about performance they will work.
Hope this helps
Old Jun 12, 2012 | 09:38 AM
Drewloera's Avatar
2000 w210 E55
I can almost guarantee its the brake light switch...
Old Jun 12, 2012 | 09:54 AM
Neanicu888's Avatar
1999 Mercedes Benz E55 AMG
Brake switch. See the long thread below about it.
Old Jun 12, 2012 | 10:20 AM
srydy's Avatar
2000 E55
Thanks for the detailed response. I will try replacing the brake light switch.
Old Jun 12, 2012 | 06:40 PM
trinitony's Avatar
E55 C43 993C2S
+1000...u know I replace two in less than 18 months...
