Cold and hot start problems
Old Dec 27, 2012 | 12:07 PM
nphra's Avatar
2004 E55 AMG
I have 2004 E55 AMG and the car start to have a problem with starting in cold or hot weather. This had happen for 6 month and sunddenlt its not start any more and the car is been sitting in my drive now. I had read many threads and most most of them saying that its can be Crankshift position senor, Fuel pump relay, Fuel Pump, Fuel filter.
Here's what i have tested so far:
1. Check spark plug and se if it spark. Yes have spark.
2. Check fuel line and no fuel come from the gas tank.
Anyone know where and how to check fuel pump and relay?
Please advise, Thanks
Old Dec 27, 2012 | 03:06 PM
desired_speeds's Avatar
2007 SL55 AMG
does it crank? you may want to post in the W211 section.
Old Dec 27, 2012 | 10:57 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Wrong section, again.
Old Dec 28, 2012 | 11:01 AM
nphra's Avatar
2004 E55 AMG
Sorry, i thougt i'm in the right section. Which one is the right section anyway? 2004 E55 AMG ?
Yes, the car crank but not start.
Old Dec 28, 2012 | 02:21 PM
2007 SL55 AMG
w211 section is the correct section. Change your crank position sensor.
Old Dec 28, 2012 | 03:39 PM
nphra's Avatar
2004 E55 AMG
That is my next step after test the fuel pump today.
Do you happen to know if the fuel pump suppose to be running when you have the key in the "ON" (not start) position?
Thanks for the reply.
Old Dec 28, 2012 | 05:19 PM
Fabio D's Avatar
210 55
eThe fuel pump would start by a few seconds when you set the key in to position 2, then turn of. when you start the car the pump should start again.
Change your CPS if the pump works good. We experimment some problems with the "Camshaft" position sensor too in this engines with the same starting problem. Make sure your Camshaft position sensor is good via DAS diagnostic. Most common faulty sensor is the "Crank" position sensor, but the campshaft sensor would get you the same issue
Fabio Daniel
Old Dec 29, 2012 | 12:05 AM
nphra's Avatar
2004 E55 AMG
I will test fuel pumps and let you know.
Old Dec 29, 2012 | 03:38 PM
nphra's Avatar
2004 E55 AMG
updates;
run 12v straigh to the fuel pump and engine start fine.
must be crank position sensor?
But i notice that when i test the power to fuel pump the the power won't stay ON when i start the engine any idea?
and is very low voltage on fuel pump wire and with that much voltage it will not power or make the fuel pump run.
Any idea? i'm think the relay?
Old Dec 29, 2012 | 07:25 PM
nphra's Avatar
2004 E55 AMG
Fabio Daniel
Fabio D,
You mentioned that the fuel pump would be "ON" when you start the car.
Here's how mine:
Its seem like very low voltage was on the fuel pump wire so the fuel pump won't run, but jump wire straight to the pump the pump fine.
do you happen know where the fuel pump relay at?
Old Dec 29, 2012 | 09:12 PM
Fabio D's Avatar
210 55
Yes mate, the fuel pump relay is in the trunk fusebox (SAM), try changing the relay first and test it again, if the problem persist i think you need a new SAM unit. is an electronic component and chec if you no have any signs of water in the module/relays/metal parts, my father's car (2005 e55) have an issue with the rear tails and i find a water leak by the trunk rubber, the module gets water inside and fail, just check and let me know. Hope you solve the problem replacing just the relay bro!
Fabio Daniel
Old Dec 30, 2012 | 04:09 PM
2007 SL55 AMG
The fuel pump should prime when you turn on the ignition. Put a test light or multimeter up to the fuel pump wiring and have someone turn on the ignition to see if you get voltage to the fuel pump. Another way is to put a fuel pressure gauge on the fuel rail and crank it to see if it gets pressure.
Old Aug 16, 2014 | 10:32 AM
smartyin's Avatar
E55
having the same problem now..
it crank and wont start..need try many times to make the engine start.
so any updates on how to solve starting problem?
Old Aug 19, 2014 | 01:04 PM
timmins's Avatar
1999 E55 AMG
Change the crank position sensor. Won't necessarily throw a fault code, unless it happens to crap out when you're driving. It's a fifteen minute job, tops, and it's easiest if you climb on top of the engine
