Shock absorbers - compatible with stock and euro springs?
Hi all,
I've done some searches but would like confirmation of the following... currently, the car is handling a bit poo over freeway bumps. Control arms all good, balljoints good, subframe mounts ok, and already replaced sway bar bushings. So I guess that just leaves shocks![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I have standard E55 springs on right now. I would like to fit shocks that will work fine with the stock springs, but which will also be ok with the slightly shorter Euro springs in case I want to lower it later. Right now I'm gravitating toward the Koni FSD's.
Does anyone have any other recommendations or thoughts?
Many thanks!
Many thanks!
