Anyone with a E55 and a Dev. SD can get me a screenshot?
Hi there,
i got a slightly little Problem. Maybe someone with a Developer SD and a E55 can help me out of this mess.
I own a Developer SD and yesterday tried to change some codes in the developer section of my ME2.8 ECU. I simply wanted to turn of the 2nd Lambda for my further Exhaust Project.
Something went wrong and now every time i open the list of implizit variant codings i get an error that one (or more) codestrings are wrong and i have to check them all. After that the whole list of codesstring is empty, every string has a "---" and i need to reselect everything.
Thias SHOULD be no problem because nothing ever have been changed (except Ciptuning) there so i SHOULD load the predefinied codestring for my E55. But after that i still got that error.
When i reinitialize the whole unit i can open the list one time, everything looks fine but when i want to save i get an "Communication error 8.561.6067".
This usualy happens wenn one string isnt programmable (like vmax to 300km/h e.g.).
As long as my ECU runs i have no big problem, but if i want to change my headers and want to delete my 2nd lambda i need to change that string. Therefor i need this to work again! :/
Please ... can SOMEONE with a E55 (07/2000 or later with ME2.8) and a Develeoper SD make me some screenshots of the codestrings? I think one ore more Strings are changed by default and because of that i get this Communication error 8.561.6067 ****.
Trying every option may take days :/
This would be really great!
greetings, Fabian
greetings, Fabian
Problem solved, i used another multiplexer and it was no problem to disable the 2nd o² sensors...
Sometimes cars are strange
greetings, Fabian
greetings, Fabian
