Acceleration Issue !!!
Belt Tensioner Replaced OEM Mercedes
Belt Replaced OEM Mercedes
Idle Pulley Replaced OEM Mercedes
MAF sensor Replaced (Mass Air Flow Sensor) OEM
Transmission Flush Done all Filters replaced Electronic connector replaced
Torque Converter Drainer and Replaced with new fluid
Water Pump Replaced BOSCH OEM
Power Steering Rack Replaced low miles part !
Air Filters Been Changed Kleeman OEM
O2 Sensors OEM
the only thing left now is TPS sensor i was wondering if it would fix my acceleration problem well here it goes:
Everytime when i drive not pressing the pedal real hard it would accelerate without a problem as soon as i try to floor it its like it dosent know what to do
i have to play with the pedal and then the rpms jump up to about 4-5k rpms and the car starts to pull really hard how its suppose to i was wondering if this problem has to do with the TPS sensor in any way because i never got any codes maybe because its not completely broke yet sometimes it works and most of the time it just dosent know what to do when i floor the car ! i would appreciate any insight on the issue thank you guys again !
