Wheel Alignment
Old Oct 11, 2013 | 03:30 PM
M3RC3D3SE55AMG's Avatar
Mercedes-Benz E55 AMG (W210)
Question Wheel Alignment
Apologies if this has been asked on the forum before. I'm a newbie and this is also me popping my post cherry.
Here's the question:
If I recently had my wheels laser aligned and checked for toe/camber, then went on to have new tyres fitted (wheels balanced of course), would it be necessary to have the wheels aligned again?
*** Something I came to know of was the fault of uneven tyre wear on W210's. It seems I'm going to suffer with this regardless of alignment but would still like the advise ***
Thanks in advance!
Old Oct 11, 2013 | 04:17 PM
desired_speeds's Avatar
2007 SL55 AMG
I would align it again after the new tires because the alignment may have compensated for the unevenness of the old tires.
Old Oct 11, 2013 | 05:03 PM
Makes total sense desired_speeds - I'll get the alignment done first thing tomorrow. Appreciate it!
Old Oct 13, 2013 | 10:17 AM
At the garage as I write this. Had all four wheels balanced again and the alignment is being done now. I have a question though. During the wheel balancing, which they said is perfect, the mechanic said the tire is "jumping" on one of the front wheels. Apparently it's a "swell" once in motion. Have you heard of anything like this before?
Old Oct 13, 2013 | 04:25 PM
2007 SL55 AMG
The rim may be bent. A wheel refinishing shop should be able to fix it and make it true again.
Old Oct 13, 2013 | 07:06 PM
Thank you! I'll get to a shop ASAP!
