AMG BRAKE
Old Nov 18, 2013 | 06:25 AM
CM0309's Avatar
W210 E240
AMG BRAKE
HI ALL,
CAN ANYONE TELL ME WHAT AMG MODEL OF THIS SET OF BRAKE? IS IT SAME AS THE C32 BRAKES?
THANKS!!!
Old Nov 18, 2013 | 09:25 AM
cm60k's Avatar
Looks like W220 S500 or S600 front brakes..!!,
why he put a long AMG sticker....?!!?
ZAYED,,
Old Nov 18, 2013 | 09:51 AM
kaype's Avatar
W109 300SEL6.3, W123 280TE, W123 200T, W210 E55
what diameter are the rotors?
Look for me also like non-AMG breaks made to look like AMGs.
W220 S500 and S600 had 330mm Rotors i think, C32/C55 had 345mm Rotors.
Old Nov 18, 2013 | 08:19 PM
CM0309's Avatar
W210 E240
Thanks for the reply, i think they are c55 brakes,
The diameter of the rotors are 345mm, and the brakes had small "345" word
on them, i want to put them on my 1999 w210 e240 but the rotors can not
fit because of the rotors hubs are "deeper" then my e240, so i want to
know that this set of brakes are same as the c32 brakes?
I search that the c32 brakes can direct put on the w210 without mod.
Old Nov 18, 2013 | 08:23 PM
CM0309's Avatar
W210 E240
ZAYED,,
I respary the brakes but buy the "wrong size stickers"
Old Nov 19, 2013 | 07:25 AM
kaype's Avatar
Mine came from W203 C30AMG CDI ... this are the same as the C32 and C55. i can not see why the C55 should use other rotors then the C30 or C32. Calipers are the same. If your rotors wont fit the W210 Axle then something is wrong... maybe the calipers are then wrong to.
They fit plug 'n play except the screwhole in the rotor, if you want to use it you have to drill a new one in your axle.
for W210 you´ll need these Part No.
MB#: A2034210912 or
ATE#: 24.0130-0180.1
both the same ... MB sells ATE Discs but packed in a Mercedes Package
Calipers are A0024202083 and A0024201983 ... you have to change sides L to R and R to L when you mount these calipers to a W210.
greetings, Fabian
Old Nov 19, 2013 | 11:06 PM
CM0309's Avatar
W210 E240
MB#: A2034210912 or
greetings, Fabian
Hi, Fabian
Thanks for your useful information , i will try to get the discs first and put them on my w210.
Thanks again,
Best wishes,
Alvin
