E55 Misfire??
Old Dec 26, 2013 | 10:28 PM
dzauto77's Avatar
2005 E55 AMG Renntech ST 5, 84 500sec AMG, 87 560sec
E55 Misfire??
Hi guys, new to the site. Looking for some advises.
Just bought an 01 e55 w/ 145k. After 30mins of driving under some acceleration CEL starts blinking. I pull over and scan it, codes are for Misfire Cyl 1 and 3. And MAP Circuit. Wanted to fix it up, i love the car !! Dont know if plugs/wires or coils were ever changed..
Where should i start ?
Old Dec 27, 2013 | 12:41 AM
Drewloera's Avatar
2000 w210 E55
Start By
Dissconect your battery for about five minutes.
Old Dec 27, 2013 | 11:28 AM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
I'll get new set of wires and plugs. You'll tell the difference once replace...
Old Dec 27, 2013 | 02:21 PM
dzauto77's Avatar
Will get wires first, what if i just change wires for the 2 cylinders that are throwing misfires 1 and 3 ? Or gotta do them all right of the bet?
Old Dec 27, 2013 | 02:57 PM
snooozie's Avatar
It's up to you, I had my indie guy put the headers in my car and he notice a splice wire hence he replace that one wire, telling me that I might have to do the rest down the road. I then decided to change the wires and plugs a month later. If changing 2 wires can fix the current problem I would do that and work on the rest later.
Old Dec 28, 2013 | 12:17 AM
dzauto77's Avatar
No clue. Im thinking since i only get misfires for cyl 1 and 3 they are both in 1 bank. So i will take the catalytic off that same bank and clean it through. Most likely clogged cat is causing it.. Will see, ill post the results later!
