2002 E55- Rear Lights
some kind of factory design, hope i'm NOT wrong..!
?ZAYED,,
Please define what you're referring to as the "rear passenger light".
First things first: In the FRONT you have TWO (one on each side of the car) and in the REAR you only have ONE SINGLE fog light. When you pull the headlight switch out once, a little green light should appear at the lower left corner just below the switch. That indicator lets you know the front lights are illuminated. Then you pull the light switch out again, and a yellow light appears, indicating that the SINGLE rear fog light is illuminated. (Please note that it is not possible to have the rear fog light on without having the front fog lights on first.)
AGAIN - there is only ONE rear fog light installed from the factory.
Please refer to the attached photos and let me know if this helps
