Transmission adapter plug
'13 C63 AMG Coupe, '01 W210 E55 AMG
I'm replacing my transmission adapter plug. I noticed some atf leaking. I know this a common problem with the plug o-rings. I also ordered some fuchs atf for the w210 722.6 tranny and a Febi Bilstein transmission Dipstick (Tool).
Replacing the adapter plug does not require a fluid drain. So, I will check the fluid level and add if necessary. Should be a simple job.
Anyone change the adapter plug??
I did it a couple of months ago. When you remove the old plug make sure you have a pan ready to catch the fluid that comes out, about a quart came out of mine. The rest of the process is pretty simple and there are several DIYs on the other forum.
2002 F-350, 1999 E55 AMG, AMG Orphans Club International Member #118
Never hurts to service the tranny. Changing the adapter plug is so easy. I did mine when I serviced the transmission, might as well, you're down there anyway. Watch that dipstick tool. Mine broke in the first bend of the tube (it was a cheap-o from AutoParts. They will warrant, but freight back to them kills the deal, so I just use it without the plastic end and measure the oil depth.) Plug is indexed, can only go in one way. Same with connector.
