The car has a low frequency shimmy at low speeds-WTH?
Old Nov 3, 2015 | 09:56 PM
Frank N Sense's Avatar
E55AMG 2000 E55 AMG 1921 Ford T Speedster
I noticed today that the car has a slight wobble at very slow speeds. It does not come through the steering wheel. It's like a bent rear rim. I don't recall hitting anything. The Wobble is most preponderant on slow right hand turns which I experimented in the car doing a full right hand turning circle brings it out.
At 8 kph my head bobbles a bit. Accelerating after 30 mph and it goes away.
WTH?
Help. Seems like a bent rear rim.
I did go in reverse and the problem was negated. WTH..again!?
Satan?
Old Nov 4, 2015 | 08:57 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Are you running spacers or are you on stock wheels?
Old Nov 4, 2015 | 09:26 PM
Hi.
Thanks for responding.
I run stock mono's without spacers.
No wheels have been taken off and put back on.
It so feels like a warped wheel or loose wheel.
Weird.
Old Mar 6, 2016 | 01:57 AM
Jan AMG's Avatar
The best or nothing
Hi,
Have you fixed it?
It could be a torque converter.
Old Apr 13, 2016 | 08:12 PM
Jan AMG's Avatar
The best or nothing
bump
Old Apr 30, 2016 | 07:35 PM
I apologize for forgetting about this Thread.
It's the rear passenger side wheel which is a bit warped as I put it on a Lathe to check trueness.
So many pot holes..
I've had the wheel fixed since and everything is fine.
