Engine cutting out
Old Nov 5, 2015 | 08:32 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Engine cutting out
I'm having another weird issue. When I turn sharply to the left or right, the engine is cutting out. Even when the car straightens, it still cuts out and sputters. Traction contol light is not coming on so it doesn't appear that's the issue. When I'm at speed and go WOT, it is fine. Just seems to happen at slow speeds when turning. No check engine or warning lights illuminated. Anyone else experience this?
Old Nov 5, 2015 | 09:58 AM
cm60k's Avatar
Could be bad CPS, or air leak from the breather hoses, somewhere around the MAF..!
did you try to diagnose the car first.?, codes may helps to narrow the issue..!
ZAYED,,
Old Nov 5, 2015 | 09:16 PM
BlownV8's Avatar
I don't believe there will be any codes since there was no check engine light.
Old Nov 6, 2015 | 12:27 AM
Tall Giraffe's Avatar
2001 E55 OMG
When my CPS went bad, it went bad in the summer. It seemed that the car had to cool down before starting. It would crank but not turn over.
I did get codes so check your codes too.
Old Nov 6, 2015 | 01:03 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Not necessarily.
I once got two codes, for the MAF and the intake temperature sensor with no CEL.
Old Nov 10, 2015 | 08:09 PM
BlownV8's Avatar
Turns out it was a bulb socket out of alignment. It was causing the brake lights to be stuck on. Adjusted the bulb, fixed the cutout and also fixed my cruise control.
